Any suggestions for OKADA products
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
I just found that website about MODS for BMW e60:
http://www.okadaprojects.com/usa/products.htm
They seem interesting.... Anyone have installed any of these?
Plasma Booster (PAT)
Upgrading an ignition system on modern cars can be a challenge: "Does not fit, Engine check light comes on, Misfire and so on.......
The Plasma Booster is EASY to install, works on almost all distributor, waste spark and coil over plug systems.
Available for 1 to 8 channels to fit your application, it is your choice.
Plasma Direct (PAT)
A Revolution in Ignition Technology! The Plasma Direct technology is built in to the coil over plug system, used on many modern cars like BMW, Audi, VolksWagen, Honda, Totota, Subaru, Mitsubishi and many more.
All your need to do is change the ignition coil to one of our perfectly fitted replacement coil and you are DONE.
Plasma Spark (PAT.P)
The Plasma Spark is the Spark Plug Boot (Socket) specially designed and developed to work as a secondary amplifier.
Plasma Ground
The Plasma Ground is a new ignition part for the BMW named "Coil Ground Tuning" !!
Please advice,
Plasma Direct (PAT)
Plasma Ground
Please advice,
My Ride: 2004 525i Executive
I know this topic is old school, but i am wondering if anyone has fitted this onto a 525i? or any of the 5s?
the price is abit steep
http://cgi.ebay.com/ebaymotors/OKADA-PLASM...sQ5fAccessories
Banned
My Ride: A Car
wow....will it make ur car fly??????
http://viosturbo.blogspot.com/2009/06/okad...no-results.html
ps is pretty much = to hp
results according here arent so bad
the most hp/$ effective mods are probably air filter and scoop and after that, it starts to get more expensive to squeeze more hp. I think this is a good mod, though a tad expensive.
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
When I read that review it seemed like a pretty good upgrade but then I saw the price and that idea went right out the window. $1500 for some damn coilpacks and all of 10hp gain! Maybe if I had already put a supercharger on my car, and fuel injectors, and an mtech kit, would I even think of purchasing this
Way overpriced! don't waste the money for just 10 hp gains with this.
Like said above: Scoops, Air filter and ECU remap yes!
