Any more room for spacer???
Hi, i am currently on this set up:
Front: 19 x 8.5, offset 18 with 245/35/19
Rear: 19 x 9.5, offset 18 with 275/30/19
I am lowered on coilover with less than 1 finger spacing.However i find my rims are sort of still hiding inside the fender, probably due to my lowering so my i know if i can add say 5-10mm spacer in front and back to push the rim out a bit more without rubbing? I have no rubbing issue with full load currently. Thanks.
I agree...A 5mm should be just fine without rubbing but if you go up to 10mm you might get rubbing issues and will have to roll fenders. Try 5 mm first and see how well they handle with afull carload...if you want to go more aggressive then you can always upgrade to 10mm down the line.
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
bestofthebest
03-28-2016 03:47 PM
