another tire question...
can 19's be set up staggered with fronts 245/40/19 and rears 275/35/19? i want a bit more rubber than the standard 245/35/19 and 275/30/19. if not, does anyone any suggestions for 19's? im looking to change my 20's to 19's with all season tires so i dont have to swap back and forth anymore. also the wifey will be driving the car at times and i basically dont trust her with the nyc streets.
245/40 R19 --> overall diameter 26.71 in / 678.43 mm
That's a 0,96 in / 24,38 mm difference and that will very likely cause rubbing.
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Originally Posted by Anzafin' post='1054629' date='Nov 14 2009, 05:38 PM
245/35 R19 --> overall diameter 25.75 in / 654.05 mm
A 275/35 R19 is 28mm larger in diameter than the 275/30 R19.
i figured they would until i calculated my 20's that are im running now and they are 245/35/20 which have a circumference of 26.75 and there is no rubbing at all. the rears are 285/30/20 which have a circumference of 26.73 and only rub when the car has a loaded trunk and 2 peeps in the back. not sure if it makes a difference but my ride is not lowered with non sport suspension. any help would be appreciated. thanx
blackstarr
Feb 13, 2016 08:34 AM
viteri10
Jun 4, 2015 01:15 PM
