5mm Wheel Spacer for Replicas 167?
My Ride: 2004 530i with Nav, Prem, 20 inch Breyton Race GTS, H&R Sport, M-technic Kits, Valentine One with Concealed Display, Progman 27, M5 Aluminum iDrive Knob, Euro Sticker Headlights, LED license Plate.
Hi all, I just installed 19 inch replicas 167 wheels with 20 rear offset. It's 9.5 with 275/30. I know some people use 12mm for their OEM 166 which bring it to offset 16. My question is will it rub for me if I uses the 5mm which will bring it to offset 15?
Seeing from the wheel gap, I do think it will rub... =(
Could someone verify this..
Thank you...
Thank you...
That doesnt sound right. if you have the stock ET20(.7 inches) on the rear and you add 12mm(.47 inches) spacer you are pushing the rim towards the fender lip which means the bulldog stance which means a final offset of ET8 which would probably rub. A 5mm which is about .2 inches should give the wheels a nice stance and "shouldnt" rub, the final offset with that will be ET15(.5 inches).
Originally Posted by rsyed' post='494664' date='Nov 15 2007, 11:58 AM
i have had on my e60 19" 9,5 a final offset of 14 and it worked fine, so you should be alrihgt with your 15...
greetinz
greetinz
Originally Posted by monacobmw' post='494738' date='Nov 15 2007, 02:20 PM
Where did the replicas come from?
Please report back with a performance report? Any vibration?
BigxPx
05-30-2015 07:51 AM
gurp99
05-09-2015 08:57 PM
