545i/550i Exhaust System
Old 04-28-2010, 12:22 PM
1600's Avatar
My Ride: 2010 M5 alpine white, black full leather, etc.
[quote name='jpar002' date='28 April 2010 - 03:12 PM' timestamp='1272481972' post='1162015']
My sentiments exactly. I need an inexpensive setup with no adverse effects that sounds slightly more aggressive than an infinity FX or G35. I need to come up with a solution soon because my M5 rear bumper is being painted as we speak.
[/quote
Then, I assume you are looking for an inexpensive quad solution? Good luck.
Old 04-29-2010, 10:17 AM
jpar002's Avatar
My Ride: 04' 545i
[QUOTE=1600;1162049]
Originally Posted by jpar002' date='28 April 2010 - 03:12 PM' timestamp='1272481972' post='1162015
[/quote
Nothing this car is inexpensive as you know.. reasonable?
Old 04-29-2010, 11:32 AM
1600's Avatar
+1 !
Old 04-29-2010, 11:51 AM
Howitzer's Avatar
Originally Posted by anand_rahim
I suppose my point of posting is to determine the best configuration that will not compromise low end torque, but still using components from muffler manufacturers like Magnaflow, Borla etc. I like that RPI produces an exhaust that has proven gains throughout, but from what I've heard on this forum, the exhaust note is a little raspy for my taste.
I love the throatier sounding exhausts, but I don't like the fact that you lose HP in some way with most of them.
That's the main reason I went with Magnaflow was because of the deeper tone. I am, however, sad that I lost some low end torque.
Old 04-29-2010, 12:06 PM
Howitzer's Avatar
Originally Posted by TAJARO
I really wonder about all the ideas without supporting data. I replaced my rear two cans with a transverse Magnaflow with dual exits, each routed to twin tips for a quad look. Similar to the Remus setup but with the Magnaflow and 2.5 inch pipses it will easily flow 6 liters. I can't tell any difference at all except for a wonderful sound. If I did lose 10 ft.lbs of torque (highly doubt it) it's still a fair trade for the sound and the look. The 550i with stock exhaust is just way too quiet and it mutes the fun of the manual tranny. Now I have great off throttle sound, zero drone and a sweet low end sound without ever being too loud.
I think the fact is most all of your back pressure and scavenging is going to be a result of your cats, and the further back you mod (in my case aft of the center muffler) I just can't believe it's all that menaingful to power.
Still as an engineer I'd need to see a lot of data to prove gains/losses.
I thought about this a lot when I saw that the magnaflow inlet was 2.5" vs the 3" coming out of the car and was very worried about a large loss of power. Fortunately I haven't noticed any change since the upgrade and I have a straight 6. I did lose about .3 MPG, but I think that is because I hold the shift until later just to hear the purrrrrr!
Old 04-30-2010, 01:26 AM
E36M3's Avatar
My Ride: Current: '08 535i Recent BMW: '95 M3 (swapped) Engine- Swapped '95 S50 with '99 S52 3.2L bored/stroked to 3.3L, kept OBD1 JE Pistons (9.0:1 compression ratio) Pauter connecting rods Schrick Camshafts Vortech V2 w/ custom bypass valve RMS Aftercooler Head modifications Ported and Polished, large valve springs and retainers, Valves Yes, but don't know name Valve springs Yes, but don't know name Retainers Yes, but don't know name Electromotive TEC III stand alone engine management, tuned by Vic Sias of Sias Tuning S50 Intake manifold Dinan Throttle Body 42lb Fuel injectors Custom RMS air intake RMS Header Custom header-back exhaust Quad exit rolled tips, polished exhaust High flow catalytic converter NGK Spark plugs B&M short shift kit Centerforce Dual Friction clutch Odyssey PC 680 Lightweight Battery Exterior- House of Kolor Moondust Silver Custom 1.5" flares molded into body Trim painted and molded into fender flares Dresmann body kit from Germany (front bumper, sideskirts, rear bumper) Kerscher 3 piece CF spoiler - imported from Germany CF side mirrors DTM Authaus CF vented hood Lighting- Gourmet Garage HID's Umnitza Angel Eyes OEM Euro tails Clear corners Interior- Seats Sparco Torino Alcantara door panel inserts silver Brand new OEM ///M3 floor mats Carbon Fiber interior trim pieces Autometer Pro-Comp Boost Gauge Autometer Pro-Comp AFR Gauge New silver/black ///M3 shift knob Custom trunk floor with amps mounted in bottom OMP Racing black suede steering wheel Valentine One hardwire kit/windshield mount Car Audio- Eclipse Head Unit (w/ sub control) Two Diamond Audio Amplifiers Diamond Audio mids, highs in car Two 15" Diamond Audio free air Subs in trunk Street Wires wiring Wheels/Tires, Brakes Front wheels 19x8.5 BBS CH wrapped in 245/35/19 Yokahama AVS Rear wheels 19x9.5 BBS CH wrapped in 275/30/19 Yokohama AVS Stainless Steel brake lines New PBR Metal Master pads in front (less than 500mi) HP Racing 15" Rotor HP Racing 8 Piston Caliper Suspension components- Front springs/coilovers (brand) H&R Coilovers (adjustable) Bilstein front dampers Rear springs/coilovers (brand) H&R Cupkit (adjustable) Bilstein rear dampers Total lowering (inches) (front) 1-3" Front RD Adjustable Sway bar Rear RD Adjustable Sway bar Sparco Front strut brace (adjustable) Energy Bushings NuFormz Chassis reinforcements (custom) Powerflex (brand new less than 1K miles)
Answer OP original question, yes, resonator can be substituted for a muffler. (I did this on my E36M3, RIP). Keep in mind the need for appropriate backpressure, as well as how LOUD it is going to be with only a resonator (or two).
pdubq
06-22-2015 08:49 PM
WolkuZ
03-09-2015 11:19 PM
SURYOYO
09-30-2003 02:20 PM
08-12-2003 11:41 AM
Quick Reply: 545i/550i Exhaust System
