535i Intercooler upgrade
Old 04-09-2012, 02:53 AM
Tiago's Avatar
My Ride: 535d
Model Year: E61 2006
Originally Posted by Persian_535i
The cooling system on the 535d is different than the 535i I'm guessing? 535i needs lots of modifications from everything I've read.
Not correct. Both have the same IC #17517791909. The inlet pipe was modified from 45º to 0º angle and it was welded wider IC supports to reuse the car IC supports. It is not a simple bolt on but it isn't also a impossible job.
Originally Posted by seev
Tiago: how many horses does your car have after the exhaust and IC upgrade ? and where can i find that IC you use ?
About 30hp and 55hp after ECU tweaking. I have all the specs of my car in my sig. The IC is from the germany company WAGNER-TUNING
Old 04-09-2012, 09:21 AM
seev's Avatar
My Ride: Bmw E60 530d
404 hp and 830 NM.. WAAAUW !!!! my car has 290 HP and 630 NM and i think its fast. wonder how MUCH faster yours is hehe..
do you have automatic transmission or manual ?
Old 04-09-2012, 12:53 PM
Pincousion's Avatar
Pincousion you have a 535d or 535i? I'd also like to know where you end up having it installed and what they end up charging or if you plan to do it yourself, lemme know!
I have a 535i 2009, was gonna install it myself, ill let you know how difficult it is. I did check with a place just to see if they would do it, and downpipes for me if i found it too much trouble. they are called Bertinis European on 45 south up here in the woodlands..they were concerned about it voiding my warranty but they said they would DO anything.
Old 04-09-2012, 01:23 PM
Tiago's Avatar
My Ride: 535d
All 35d engines only have automatic gearbox. There are a guy from sweden with a 335d putting down 445hp. These engines have a insane potencial.
Old 04-10-2012, 10:49 AM
seev's Avatar
okay.. thats sounds wild hehe. what about the transmission ? can it hold to that much NM ? do you know if i have the same transmission as yours ?
predshaw
13
11-22-2021 05:58 AM
jinsta
07-22-2015 08:29 AM
ucsbwsr
07-10-2015 01:54 PM
Inty
07-09-2015 09:48 AM
cnwakobi
07-09-2015 09:46 AM
Quick Reply: 535i Intercooler upgrade
