535i 2008 LED replacement
Do you have xenon headlights? If so I wouldn't recommend going crazy with your flash to pass bulbs since the Xenon bulb does both low and high beams. I have Xenon headlights and did the whole LED thing in the inner lights (flash to pass) and the fog lights but purely for looks since the xenons are really bright and I can't even notice the LEDs when using the high beams. You will also need to install resistors or code the LMA to get rid of any error messages after installing the LEDs. I went for the later and coded the LMA which is really easy and haven't had a problem.
Luvspeed
Nov 15, 2015 05:46 PM
