535d LSD by Quaife
My Ride: 535d
Model Year: E61 2006
From time to time i search on google a LSD for my 535d to see if it is already available. I found that Quaife has a LSD for the E60 530d I checked the realoem and realized that the differencial from the 530d and the 535d seem to have the same size because both share the same part numbers of seal gaskets, bolts, and output shaft. The only difference it seems to be the final drive:
03 E60 530d - 2.47diff ratio with 0.70 6th gear ratio
04 E61 530d - 2.65diff ratio with 0.69 6th gear ratio
04 E6x 535d - 2.56diff ratio with 0.69 6th gear ratio
06 E9x 335d - 2.81diff ratio with 0.69 6th gear ratio
If the Quaife LSD have the diff ratio of 2.65 and if it is direct application it would be great because it would make the car a bit faster. Does anyone know if the 530d diff and 535d diff have the same dimensions?
jashy247
02-23-2021 05:50 PM
