530xi Lowering Questions
My Ride: 06' BMW 530xi
Hey, since the xi is limited to alot of parts (especially the m5 rims) :/ I want to know which is the best way to go to lower my car ... coilovers are priced way too high lol the only springs I found was the H&R lowering springs (does anyone know where I can get them cheap?) or have an alternative brand I could use that's better than H&R? Thanks.
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
Noise in the coilovers can be solved as far as I know... youtube "KW coilover noise" - as long as you use the second cap (or whatever its called), you should be just fine.
I personally am planning to replace most of the mounts (and all the "rubbers" I can find upgrades for ) when I get the coilovers put on. Also, I'll be looking for some stronger control arms etc.
Calton, anything you'd like to add?
Lastly, DO NOT GET THE SPRINGS ALONE - your ride will be ruined
My Ride: 2010 535xi
I'm in process of ordering the KW's for my car right now. Since the sport package XI's don't have the real sport suspension, I figured I wouldn't be happy with H&R springs and stock shocks. I don't really need the adjustability of the V3's, but it's the only option for the ugly, read-headed stepchild known as the XI
I'll let you know how it goes regarding the squeak/rattle. I'm praying that I can minimize it (or not have it all). I'll be putting 19's on at the same time, so we'll see how everything works out.
Let's keep the information flowing - us XI members need to help each other out!
Like new 41k
Now, how can I make them blow out fastest?
Also, when I contacted KW about the noise, they said to just call them directly about it (which I never did ), so it seems like they'll never abandon their customers and will work with you to eliminate any issues
I know how - send 2000 to KW
Those coilovers will blow your shocks off immediately
So, if I get the H&R springs what else should I get? My car has about 35,000 miles on it so the suspenion is pretty good for now ... and Yeah the roads in new york aren't the best streets to drive on especially since I live in one of the 5 boroughs but I can't have the car that high lol
Dude, honestly, there's nothing out there that is public information that works with the H&R springs. That is why I'm getting the coilovers eventually. You know what H&R's do - I know you've been reading up on stuff - you'll be bouncing like some low-budget low-rider... well, ok, maybe not as bad as I'm making it sound, but it will ruin the ride. I was gonna tell you to try looking through OEM replacement struts/shocks, but I'm sure others have tried and failed there. However, if you're truly persistent and succeed at finding an alternative to the coilovers, then you're still stuck with trying it out on your own car, at your own expense... basically, there is no going around it - coilovers are necessary to do the drop right.
Like new 41k
They don't make aftermarket shocks for our cars to go with the H&R's. Those are truly your only 2 options springs only or coils.
Like I said before I have the springs and they work great for me 90% of them time (on good roads). On the crappy roads it sucks so I try to avoid them as much as possible.
