530D Turbo
My Ride: 530D, Lowered, Privicy glass, De-chromed, 18"wheels, AC Schnitzer lit, ipod interface, blue tooth prep,
Hi all,
Just got home after having my car recoverd off the motorway...
It would apprear that my turbo has failed on a car with only 44k miles on the clock - is this usual?
The turbo is rattling with no power being available above 1500 rpm will plooms of smoke from the exhaust.
Would appriciate some advise on replacing the turbo!
Should this be dealt with by a main dealer only or could a competent local garage take on the repair?
Do you think i should purchase a reconditoned turbo or risk a second hand one?
Any advise would be appriciated - as i'm sure this is going to be an expenisive job.
Car Model - 530D 2003 SE
![Mad](https://5series.net/forums/images/smilies/mad.gif)
My Ride: 535d
Model Year: E61 2006
Originally Posted by jonestheman' post='457856' date='Aug 12 2007, 11:38 AM
Hi all,
My Ride: E60 550i LCI M-Sport, Carbon Black
I am not sure if this is common or not but when searching for a 530d for myself, one of the potential cars I went to view had a brand new turbo fitted under warranty - same issue as yours.
I was also told that when the turbo screws up, a pool of oil gets washed down the whole exhaust system - which meant that the whole exhaust system including CAT had to be replaced.
Sorry to make your already terrible situation worse....i don't suppose your car is under warranty by any chance?
If not then try your hardest to fight with BMW to get it done for free - but it is likely to be one heck of a battle though
Good Luck.
Good Luck.
Hi all,
My Ride: 2011 550 AW
2005 530AW GONE
Good Luck.
Good Luck.
Nyulak
03-23-2016 07:22 AM
th3h1ghlander
10-09-2015 07:40 AM
timmay77
09-24-2015 09:38 AM
timmay77
09-23-2015 12:34 AM
