525d lots of white smoke after remap??
Yesterday i had a remap of my 525d. The results where awesome: 223,7 Hp and 509 Nm
Yesterday when i drove home a had a lot of traffic jam so i drived really slow.
Now when i had a "sporty" ride today i stopped in front of a traffic light. Then i couldn't see the guy behind me anymore. There came out a lot of white smoke out of my exhaust.
I get out of the car and i smelled like burned plastic
Does it have anything to do with the particle filter or is my turbo or something blown?
I'm a litlle bit scared about it.
My Ride: Estoril Blue 440i GC
Model Year: 2017
SX125,
I would be scared too!!
White smoke from the exhaust usually means that water is somehow getting into the engine. i.e. you can see steam!!
You urgently need to have a look in your radiator to check the coolant level. Also check the oil level, if it has gone up, then water has got in there as well.
I wouldn't attribute it to the re-map directly. If it was black smoke, then maybe, but re-maps don't do anything for the cooling system. On other cars, then I would be looking at maybe head gasket gone, or maybe even a cracked head. I take it that you didn't get the high coolant temperature light come on? (between the speedo and tacho).
I wouldn't like to run a car that was exhausting white smoke all the time - you need to get it checked out soon.
Mike
Mike
Originally Posted by AlwynMike' post='423246' date='May 11 2007, 02:09 PM
SX125,
Mike
Mike
But the problem is that it happend only 1 time no after the remap.
Today i didn't see it again.
I'll check the coolant directly after work, also the oil level.
Isn't it the automatic geren. of the particle filter? At that moment the car will be idling a little faster/rough, and can produce a strange smoke/smoke.
thesalboy
04-08-2015 09:13 AM
