285 tire on a 530xi
Can I run an 9.5X19 inch wheel with a 40mm offset and a 285/30/19 tire on the back instead of 275/30/19. Will this cause rubbing? I figure if you can run an 19X10 wheel with a 38mm offset on the rear, then I'll gaining 2mm+ offset (40-38) plus about 13mm+ on the difference of the wheel (10"-9.5") to make up for the difference of the 10mm in tire size (285-275). Will this work even if I lower the car with H&R Springs?
PrimeTimeTSA
08-15-2015 02:14 PM
