Hello,
Is anybody know if the 2008 LCI angel eye light source is compatible to pre 2008 E60 ? The 2008 are much more white collor brighter compare to the yellow on pre 2008. I try to upgrade with Umnitza Predator ICE V2 but it's not as good as the 2008. Thanks |
They are not compatible. If you want the LCI look (and lights) you will have to retrofit.
The Post-08 models use an H8 bulb for the angel eyes whereas the pre-08's use a specific fit angel eye unit that is completely different in design. The two are no interchangeable without swapping out the entire headlight assembly.
