20" 2pc Iforged Forza (Hamman limited edition)
I am looking at these 20" 2pc Iforged Forza (Hamman limited edition)
ront 20x8.5 on 235/30/20 Falken Fk452 tires
Rear 20x10 on 285/25/20 Falken Fk452 tires
Don't know the offsets since iforged doesn't release them..
May I ask if the 545i will sit nicely on these lovely rims?
I never lowered my car, and the car does have sports pack.
Will there be rubbing?
My Ride: 2004 545i stock
Without the offsets it will be hard to tell. If they are coming off another BMW model you may be able to guess a round about number for the offset. But then it would be a guessing game hoping you guessed right. I did not know the offsets for my iforged but knew they came off of an e90. You can try due measurements to calculate your offset. Google how to measure offsets. This is what i did to get a close figure on my offsets.
They came off of an e90 as well.
His reason for selling them is that he sold his car.
But i don't know if he had rubbing issues...
are your iforged 20" ?
e90 offsets are higher than e60 offsets. Most RWD e60's will require spacers to push the offset a bit more flush with e90 wheels, e60 awd offsets are more similar to e9x offsets....
is the member local to you for a test fit?
Mine are 19x8.5 and 19x10. I used 15mm spacers in the front and 20mmin the back. I could get away with10mm and 15mm in the back. Like an earlier post indicated if the seller is local see if you can test fit them. When i did not my rough calculation using the method i found my measurements came out to be front 32 and rear 37.
by the way , these r the wheels
http://i174.photobucket.com/albums/w...9/photo1-1.jpg
http://i174.photobucket.com/albums/w...9/photo2-1.jpg
http://i174.photobucket.com/albums/w...9/photo3-1.jpg
these seem to be in mint condition, i will be taking a look at them sometime tmr or very soon..
seller pretty firm on $2400 rims + tires ..
iforgd wheels are okay, i've seen this wheels posted on e90 post for sometime now, make sure ask seller
how long and hjow many miles he ran on them? also is this a 3 piece wheels? my suggestion is save a couple more thousand and just get HRE or BBS or DPE wheels thats just my opinion
how long and hjow many miles he ran on them? also is this a 3 piece wheels? my suggestion is save a couple more thousand and just get HRE or BBS or DPE wheels thats just my opinion![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
He said these are 2 pc?
I really like these...
