19" OEM M6 rims will they fit E60 530 anybody know?
yes the wheels will fit, but if they wheels have OEM M6 tires on them, you will need to change the tire sizes...
here's a good reference for tire sizes:
https://5series.net/forums/index.php...opic=54583&hl=
recc'd size is F 245/35, R 275/30
Wht tire sizes are you running? OEM M6 tires usually are wider front and back. For NON-M5 E60, you should run Front 245/35, Rear 275/30
EDIT: Same time me and you Gene. But you beat me by a spilt of a second
I knew I should've got them Turbos
![Getlost](https://5series.net/forums/images/smilies/imported/getlost.gif)
Originally Posted by kelimak 96' post='1041888' date='Oct 28 2009, 10:25 AM
will OEM M6 19" fit my E60 530 2006 without any issue? anybody know? thx
check the offsets or you may have rubbing issues
Fronts ET:12
Rears ET: 17
I think many people here get the 166s and 167s with M6 offset so that they can be flush and are ok as long as they go with the above offset.
Originally Posted by Bteljuice' post='1041901' date='Oct 28 2009, 10:39 AM
Hey M630 ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
My Ride: e60 , 6spd silver/black carbon intr....
They fit, I have them in the M6 offsets.
Check my thread.
https://5series.net/forums/index.php?showtopic=87717
Fronts rub a bit on sharp bends in the road, but mines pretty low at the front. I also had to trim a small section off of the inside of the wheel arch, where it meets the front bumper. You can see what I mean if you take a look at your wheel arch.
The backs don't rub at all.
Check my thread.
bestofthebest
03-30-2015 08:12 PM
