19" and 20" Wheels
My Ride: 2004 545i, 1995 M3
I am about to get larger wheels for my 2004 545i. My car has the sports package which includes the active suspention. I know from the past that adding larger diameter wheels can make the car look like a 4X4 unless you add springs. I have not seen springs available for my car nor do I want to lower it. Have any members added larger wheels without springs? How did it look? Have pics? I will be getting a stagged setup. Are there certain sizes and offsets i should be looking for. The reason I ask its that I noticed some members use spacers to push out the rear rims, I would rather not do that and get the correct offset from the get go. What sizes would require fender rolling?
Thanks
Bill P
Thanks
Bill P
if you change you mind about lowering your car, there are actually springs available for your 545, also coilovers if you choose that route. as for the wheels, here's a thread where eurocarfan has put pics up when he first put on 20" rads with still stock sport suspension on his dinan 5: http://forums.e60.net/index.php?showtopic=...&hl=freedom hope this helps.
madein
06-06-2015 11:48 AM
Virak1985
06-02-2015 11:16 PM
