10mm Hub Centric Wheel Spacers 72.56mm to 74.1mm
My Ride: 2007 530i
hey guys, i have a 2007 530i non sport with replica miro M6 style wheels, i currently have hub rings (72.56 to 74.1) on the car but the only problem I'm having is that every time i get my wheels balanced the shop will break the plastic hub rings resulting in buying a new set everytime. I'm looking for a more permanent solution, Has anyone tried Hub Centric Wheel Spacers 72.56mm to 74.1mm? these come in 10mm, can these solve my issue with replacing the hub rings and also will they cause any sort of problems? I'm looking into applying on all four wheels..
http://www.ebay.com/itm/2-10mm-Hub-C...ht_1146wt_1378
http://www.aliexpress.com/product-fm...olesalers.html
My Ride: 2004 525i
Maybe buying several sets of rings is a cheaper option. I was looking too and just searched fore 74.1 72.56 on eBay. The result was a ton of options around $10. With several rings on hand, you can just replace the ones that break.
My Ride: 2007 530i
chadillac2000
42
09-13-2017 11:15 AM
PrimeTimeTSA
08-15-2015 02:14 PM
