Zero at Short term fuel % trim
Hi,
my 2008 528i had check eng light. After some work done including verified all fuses are good including those in ECU, I am more leaning towards the O2 sensor. The code is P165F and 2CA6. The voltage readings for B1S2 and B2S2 are seemed fine (0.5-0.7v). But no readings for B1S1 and B2S1. Today I noticed the STFT1 is always at zero. STFT2 is OK moving up and down. Also LTFT1&2 are OK. See attached. Is the zero meaning the bad B1S1 O2 sensor? Thanks https://cimg2.ibsrv.net/gimg/5series...6594278238.png https://cimg3.ibsrv.net/gimg/5series...f9a7341af.jpeg https://cimg4.ibsrv.net/gimg/5series...286ca90803.png |
I went ahead and changed the O2 sensor on B1S1. Same problem remains. The reading is still 0. Same P165F code with Check Eng. light on.
| All times are GMT -8. The time now is 08:45 PM. |
