If you have factory xenons, are the side light aldo xenons?
Im thinking that it might look weird if you have white xenon headlamps and a yellow angel light around it. Has anyone got pics of the xenon headlamps? |
1 Attachment(s)
Here is a picture of the xenon frontlights, and the parkinglights...
:cool: :cool: |
Thanks, the headlight is not on in the picture.
check out this picture from Memotronic's gallery...
http://forums.e60.net/index.php?act=module...&cmd=si&img=354 |
Wow, looks nice. I thought the angel light would have been yellow.
Does anyone if you get the xenons, is the angel light the same or not? |
I've got the Xenons and my angel lights are yellowish.
http://forums.e60.net/index.php?act=module...&cmd=si&img=354 [snapback]121964[/snapback] |
Im thinking that it might look weird if you have white xenon headlamps and a yellow angel light around it. Has anyone got pics of the xenon headlamps? [snapback]121928[/snapback] |
Thanks Merv :)
The only light that is xenon is the outer headlight on bi-xenon equipped cars. The inner light only comes on if you flash your headlights and uses a normal halogen bulb. The "angel eye" rings are a light conductor a Merv says. A single bulb is used to filter light around the ring. This is easier to see on the new 3 series as the light rings sit forward of the rest of the headlamp assembly in this model.
