xDrive Rim minimum offset
Old 01-23-2015, 09:01 AM
harley164's Avatar
My Ride: 535
Default xDrive Rim minimum offset
Hi guys,
I know there are a ton of posts on this, but I've been unable to find the answer I'm looking for.
I've got a 2010 xdrive e60 sedan.
stock rims are '17 with what appears to be a 40/43 mm offset.
my question is, what's the lowest offset I can go with a 17"? i want to keep a 7.5/8" width which seems pretty standard. when looking on tire rack they are offering 35mm offsets as the lowest, although i read a thread that said you can go lower.
for instance, there's a set of 327's off a 2012 drive 5'er and it's got a 30mm offset.
can i put these on my car and have it stick out just 1cm and be ok?
thanks,
dave
Old 01-23-2015, 10:39 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Welcome to the forum, Dave!
I also have an xi and I've always regarded 35 - 45 mm to be the offset range for our cars. 30 would be pushing it.
Old 01-23-2015, 02:35 PM
harley164's Avatar
My Ride: 535
Default so close?
i found these
BMW wheel style 327 | BmwStyleWheels.com
30mm offset - will they stick out too much? sooo close . . . .
finding rims for an e60 xdrive is impossible
Old 01-23-2015, 05:56 PM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Actually...
X5 (E53 - 1995 - 2006) and 3 Series (E46 1999 - 2005 - non M) wheels also have compatible offsets to the E60 xi).
You can compile your wish list here: http://www.bmwstylewheels.com/
Old 01-24-2015, 03:42 PM
audiophool's Avatar
My Ride: 535xi
I have BBS SR 18x8.0, 5x120, +32offset – fit just fine
Old 01-24-2015, 04:50 PM
harley164's Avatar
My Ride: 535
so if a 32 fits fine . . . . a 30 is not too far off.
the difference between a 40mm offset and a 30mm is that the wheel will stick out 1cm . . . that can't be too much?
thanks for all your help!
can i go as small as a 16" or do they have to be 17's? I think I need 17's for the rotor, but just checking - thanks!
-dd
Old 01-25-2015, 12:32 PM
audiophool's Avatar
My Ride: 535xi
Here it is with ET32 and 245/40R18. A couple mm less would probably be fine as long as the tire width is right. I've used 10mm spacers on the front with the stock 17" 43mm offsets, 12mm on rear.
Old 01-31-2015, 01:28 PM
harley164's Avatar
My Ride: 535
thanks guys - so what about on the other end . . . .
i found these 3 series 17" rims with a 47 offset - is that too much?
BMW Wheels - 17"
BMW wheel style 44 | BmwStyleWheels.com
thanks again!
Old 01-31-2015, 04:07 PM
quanger's Avatar
My Ride: 530Xi
I have 19 staggered, 8.5/95 with 35et lowered, rubbed on the rear till i got it rolled. now if I want to I can add on another 5mm. But if yours set are only 7.5/8, and your car is not lowered, then 30 et can work.
Old 02-01-2015, 08:44 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
BMW Wheels - 17" - Post removed
thanks again!
Nope! You should be good.
msaudino
11-01-2015 03:52 PM
wraduenz
09-25-2015 07:40 PM
bimmerspeed
09-23-2015 03:50 PM
hpuck
09-21-2015 04:17 PM
Quick Reply: xDrive Rim minimum offset
