Xcarlink Multimedia
My Ride: 2011 535i xDrive M-sport
I got the Xcarkink multimedia interface and it has an RGBS input. What type of device(s) use this type of connection? I was told that this is will not work with a component connection, what is it for?
"The use of component video cables for RGB causes the most confusion, firstly the two signal systems are not compatible, if you try to connect component video to RGB you will not get a picture. The problem with using component video cables for RGB is that most consumer electronic devices require a video sync or a horizontal and vertical sync"
Bank$hot530
07-12-2015 04:36 PM
sndohio
06-21-2012 07:01 AM
pablo_ni
10-27-2010 11:49 PM
