Fuel Pump / Overfill Gas tank accident
My Ride: 535I
a little help or suggestions. I accidentally overfilled my gas tank. Clicked off prematurely and thought it was not full. I WAS WRONG. Now have gas smell coming from right rear..
No fuel pump codes and was running MHD 25% E85 map.. No fuel pump upgrade.
DCI
CPE charge pipe
Wagner FMIC
Inlets
Am i screwed of what?? Charcoal Canister? evap mess.?? No smell in the car just outside the car. Been about a week now, and ran the tank to under 1/8 and refilled with standard 91OCT. re-flashed to stage 1+
DCI
CPE charge pipe
Wagner FMIC
Inlets
DCI
CPE charge pipe
Wagner FMIC
Inlets
DCI
CPE charge pipe
Wagner FMIC
Inlets
My Ride: 535I
thanks for the reply. The only change that I really noticed is the cars idle is a little rough. I reset the Lambada and octane rating flashback is stage 1 it's been running smooth for the most part. When I adjusted the idle and mhd settings to 750 it did take the idle away a little. I am getting 2fca 2fda shadow codes. They say high pressure and then german.. all the research that I've done on these two codes have nothing to do with the fuel pump though really weird and low pressure fuel sensor is running in the 70% range which is normal I think
man..
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
your fuel pump won't be affected. You overfilled and it flooded the charcoal canister. Will take a long time to dry up. May cause other emissions/evap errors, not sure. I'd just wait it out.
My Ride: E60 2010 535i /FBO
Model Year: 2010
Been getting High Pressure shadow codes but inactive. Going to clear through impa. Fuel pressure running 70's -80's and think that is normal. No signs of fuel pump failure thus far!
