would this rim fit my 04 545i?
My Ride: Bmw 530d 2004
Originally Posted by khooger' post='596143' date='Jun 5 2008, 06:35 PM
I bought the BBS RSGT's from an E39 M5 and they fit my 545i. Is there a difference?
My Ride: 2004 545i
Production date: 02/04
Color: Black Sapphire Metallic
Trim: Anthracite
Options: Sport package with STEPTRONIC, Premium Sound, Rear Sunshade, Xenon
Originally Posted by Anzafin' post='596146' date='Jun 5 2008, 11:41 AM
There must be some loose between the hub and the wheel then if you don't have hubcentric rings
--> not good.
Originally Posted by khooger' post='596147' date='Jun 5 2008, 06:44 PM
Is it the fronts and back as well? Does the hub rings come with the same size?
My Ride: 2004 BMW 545i, M-Sport Bodykit, Sports Suspension, Sports Seats, Active Steering.
From experience with using slightly different hub sized BMW wheels on past BMWs, I still experienced a slight vibration at speeds > 100 kph, even with hubrings fitted. It's your decision, but I would refrain from installing non-compatible wheels on my E60.
Potential vibration is definitely a drawback of using hubcentric rings. I've had a situation when 90% of vibration disappeared. But then again, I've had situations where hubrings eliminated all vibrations. So if these are the wheels of choice for you, make sure you go into it knowing the potential outcomes, to prevent any possible disappointment.
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
The offset of the front would probably work. 166M rims are a 12mm offset and for a non-M car should really be 15-18.
The back should have an offset of I believe 28mm. So, a 15mm offset on the rear would probably stick out too far which can not be corrected.
DILLESTJAMZ
05-05-2015 12:56 PM
bestofthebest
03-30-2015 08:12 PM
