View Poll Results: Is it worth keeping after warranty expiration?
Voters: 15. You may not vote on this poll
Is it worth keeping 2008 BMW 535xi E60 N54 after warranty expired?
My Ride: 2008 BMW 535xi
Hi,
I purchased 2008 BMW 535xi (E60 N54) in Dec 2010 (as preowned certified) and it has a warranty until Jun 2014.
I have a question and need an advice if I should keep it or better sell it before the certified warranty expires.
As per my experience my vehicle is in the shop every 2-3 month. Below are the major repairs which were done to it and dates.
What do you guys think if it is worth keeping the vehicle now or it will keep getting broken on me. I’m asking this questions because repairs can be costly, however with all the parts already replaced, maybe be there are no other major repairs are due for a while? Maybe all new part will be warrantied for a couple of years and will be good for another 4-5 years from now? Or perhaps someone knows that there are other major parts which get broken on this vehicle? Or maybe it is good to keep vehicle now (after all this repairs)?
List of completed repairs:
Dec 2010 - Replaced High Pressure Fuel Pump
Mar 2011 - Replaced both cat converters
Jun 2011 - Replaced both vanos solenoid valves
Jul 2011 - Found BRG Ledges excessively worn, replaced both intake/exhaust camshaft ledges and 4 hook ring seals
Oct 2011 - Neither valve was sealing. Replaced both turbos
Sep 2012 - Replaced 110Ah Battery with new 90Ah. Performed retrofit coding
Aug 2013 - Replaced Water Pump
Aug 2013 - Replaced all 6 Fuel Injectors
Thank you for your time.
My Ride: 2008 535 XI
Mark, good question I'm in the same boat as you. I bought new 2008 535XI just turned 26,000 miles, just waiting for the gremlins to come out
My Ride: 2008 535XI
I'm your boat as well as well. This is my first BMW, 2008 535XI with 34k. CPO warranty is done Jan 2014. Radiator coolant flush, oil pan gasket replaced, transmission pan gasket replaced and the oil cooler housing gasket replaced and blow off value bank 2 replaced. I have no idea what maintenance was preformed with the previous owner if any. I have only 38K on it now and owned it 4 months. Needless to day, don't go back to your dealer once the CPO is expired. Find a good indy shop and good luck. I already have my eyes on the 2011 550 xdrive if this car turns into the money pit.
chadillac2000
42
09-13-2017 11:15 AM
