adding sport button
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
adding sport button
Hi all any one fit a sports button to a f10 msport and is it the as the e60 wire it to the pdc
It's to the same module, were the plug would go.
Model Year: E60
Engine: 2.5
sports button
Is that the pdc button.its a 11 msport f10 but has no sport button I did this on the e60 number 8 and 10 on the pdc button
As long as there was a sport button option, you can connect to it. The sport button worked without coding with some, but read that it worked most of the time(that's e60). The only thing that needs coding is the gear selector. If you can fing the pins, it's worth doing, makes a difference that you can feel.
Model Year: E60
Engine: 2.5
sports button
Their is no sports button and the e60 was the same but I wired one in and it worked I want to do the same with the f10 msport but need to find out if some one added one
My Ride: BMW 550I BLK
Engine: N62
hey check out Utube post by " roskinc " just type in e60 sport mode button, her has. few vids showing the whole process. he even sells the units. I watched the vids a few time and I did it in 30 mins and I slow
As long as it was available, it should be able to do like the e60. Find the two pins with a momentary button.
