Winter already??
It's about 90 degrees where I live right now, and so naturally I'm thinking about my winter set up for my wheels and tires.
I need some help and advice. On my E39, I just switched winter tires back and forth on my same rims, which really isn't the most wonderful idea. So with my '08 528i (with sport pkg) I was going to buy a dedicated set of winter rims and tires.
My question is whether I will see/feel a noticable difference if I stay with a set of 18s (and 245/40/18 winter tires), or if it is much smarter, safer, and noticable in handling to drop down to a 17 inch set (with 225/50/17).
If the difference is negligible, I'd rather get a set of 18s, but if there is a true, noticable difference, I will get the 17s (probably a set of the stock 17s that come with the 535i non sport pkg).
Any suggestions/insight?
Thanks.
Thanks.
I run with 18" wheels in the winter and the ride is fantastic. I use the OEM stock 18" wheels (style 124, staggered) that came on the 550i sport. Dunlop Winter Sport M3s are a great choice for winter rubber.
Boy, you really plan ahead.
My Ride: 2008 550i ZSP with Style 167 wheels
I think I've seen your post on this before, but my brain can only hold so much!
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Lou
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Originally Posted by BMWSTL' post='446947' date='Jul 12 2007, 06:06 PM
Are your snows all the same size (245/40/18) or "standard staggered size," i.e, wider in back (275/35/18)?
Lou
Lou
I'd guess the difference between 245 and 225 will probably be minor, unless your either in the mountains or the lake effect regions of the Great Lakes.
One upside of the 17" rims will be a smoother ride during pothole season, with less probability of wrecking a rim.
Lou
Lou
My Ride: 2004 545i Silver Grey Premium Package, Sport Package, Dynamic Driving Package
Anyone running 215/50R17 for snows? I have the sport package so I have 18" and when I calculate the numbers, the 215/50R17 is closer to stock diameter than 225/50R17.
Originally Posted by iversonm' post='447021' date='Jul 12 2007, 08:59 PM
You don't want really wide snows. Narrower tire perform better. There really is no reason to run a staggered setup.
I figured the narrower 225 would cut through the snow better, and the 50 sidewall would be better with the winter potholes. I take my daughter to and from school and so I figured why take any chances, even if the smaller wheel may not look as good and the 243 rim isn't exactly the most beautiful thing on the road. It's only for 3 months, so why take chances.
Again, thanks for all the advice!
If you want a safe and confy set for the winter go for the OEM 17" wheels and 225/50 tyres.
Buy the best winter tyres there are, not any all season ones!
Vman33
03-14-2022 04:43 AM
