windshield washer pump
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
My windshield washer jets are not spraying. I don't think they are clogged as it is the same on both sides (all 4 orifices). The first spray is about a 1/4 way up the windshield and goes down from there. I would be surprised if the pump was giving out, but that is my first thought.
I have not really looked into it, but figured someone may have some advice.
I do have fluid.
Has anyone had a problem with the pump? Does it have any filter element?
I do have fluid.
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
How do you direct the windshield fluid nozzles? Mine tend to go all over the place?? Is there any particular technique to re-aiming the nozzles???
![](https://img.photobucket.com/albums/v201/EV4530/Capture23.jpg)
I do have fluid.
I do have fluid.
My Ride: 530D SE
I cured the same problem (everything working but just a dribble from the jets). Disconnect the hose at a common point and blow air down to the water tank. I used a foot pump by hand. After a bit of gurgling It was fixed.
As for the other post re: adjustments. If your jets are like mine they are fixed slits which spray across the screen. There is no adjustment.
Hope this works for you!
Originally Posted by EV4530' post='713379' date='Nov 5 2008, 05:38 PM
It could be the strainer grommit, but do you hear the pump working when you hit the switch? If you do, then that might be your problem. I had the dealer replace the strainer grommit which was clogged up. Hope this helps & good luck
i had the same problem, i took my car into the garage for yet another pdc failure problem, and i asked them to take a look. they charged ?50, they said they removed the water tank and cleaned the filters out. 100% better now though.
Vman33
03-14-2022 04:43 AM
JayArras
05-29-2016 06:35 AM
bestofthebest
03-28-2016 02:47 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
Florida2002m3
09-01-2015 10:59 AM
