Windshield washer pump
Old Mar 6, 2012 | 01:12 PM
Coastie5685's Avatar
I can not seem to find where the hell the washer pump is located.
I get no spray out onto my windshield and I hear nothing moving.
Old Mar 6, 2012 | 01:17 PM
luigi524td's Avatar
This topic has been covered by several posts ... searching the forum can be time consuming but could save you a ton of money ...
https://5series.net/forums/topic/120...1#entry1417387
Of course if money is no object your BMW dealer will probably make house calls
Old Mar 6, 2012 | 03:26 PM
AchtungE60's Avatar
My Ride: E60 530i
You know, I never had time to look into this...I have the same problem. Mine was perfectly find and then I disconnected the sprayers and took them off my hood to polish it and since then it doesn't want to spray. That was about 6 months ago and i STILL havent looked at it. I'll put it on the list of things to do tomorrow.
Old Mar 6, 2012 | 03:47 PM
tonyb635's Avatar
You will find it located inside the driver side forward wheel well. You need to remove the screws on the front side of the line and peel it back. You should see it.
Old Mar 6, 2012 | 06:08 PM
Gotcha. So remove drivers side front wheels and pull back wheel well lining? Or access inside engine bay front driverside?
Old Mar 6, 2012 | 09:05 PM
Gilgorm's Avatar
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
Windshield washer fluid tank is front and centre in the pic. Mine is full of yellow winter Rain-X. The pump is located on the side of the tank facing the tire. The inner wheel well was removed in the pic.
Old Mar 7, 2012 | 01:08 AM
tonyb635's Avatar
Exactly, remove wheel, and then the front portion of the liner and you will see it.
Vman33
Mar 14, 2022 04:43 AM
JayArras
May 29, 2016 06:35 AM
bestofthebest
Mar 28, 2016 02:47 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
Florida2002m3
Sep 1, 2015 10:59 AM
