windows dont work
Old Jul 9, 2005 | 08:51 AM
abs's Avatar
abs
since i have had my software update to version 17 not only do my amber lights not work but the driver side window has developed a fault.
when i try to close the window it stops at half way and goes back down again. i am left to close the window by pulling the window up bit by bit.
does anyone else have this problwm as my dealer has yet to resolve it
Old Jul 9, 2005 | 09:26 AM
stream's Avatar
Banned
Apparently a fairly common problem with the anti trap function--I had it intermittently on my passenger window--they replaced the window drive and now works properly. Now I have same problem with drivers window...
Old Jul 9, 2005 | 10:41 PM
goyk's Avatar
My Ride: 2005 545i, Black on black. 6spd MT, Nav, sports package.
I have the same problem... I never got any software upgrades.
I thought it had something to do with my tints.... At least thats what i think the dealership will tell me.
Have you had your windows tinted?
Old Jul 10, 2005 | 03:13 AM
Yankee's Avatar
My Ride: E60 - 520i Dec 2004 built Previous 320i for 5 years
[snapback]147256[/snapback]
According to our distributor in Spore, the drive motor has some problem, need to have it replaced.
Old Jul 10, 2005 | 03:24 AM
abs's Avatar
abs
[snapback]147482[/snapback]
no my windows are not tinted
Old Jul 10, 2005 | 05:09 AM
g8r's Avatar
g8r
My Ride: 2005 530i jet black, NAV, premium, automatic, xenon
I am having the same problem. I took delivery in Nov. 04 and have not had ANY problems until this. It just started about a week ago. Automatic function does not work properly. I have to press button several times and window moves about one inch with each press of the button.
I have my first appointmnt for service (10,000 mile oil change) this week and they will hopefully repair the problem. I will repost after I hear from the service advisor.
I have not have a software upgrade, nor have I had the windows tinted.
Old Jul 10, 2005 | 05:18 AM
DR.Z's Avatar
I'm also having problems with my passenger side widow.
But only when my accountant and Father-in-law are in the car, comments like " so this is
$ 65,000 worth of German engineering huh " .
BTW I have only had one update version 13 , but that was some time ago.
DR.Z
Old Jul 10, 2005 | 05:24 AM
E60Speed's Avatar
My Ride: 545i Mystic Blue/Black Leather Type 124 Wheels
maybe you guys should try to re-initilize the window (teach the anti trap where the fully closed and open positions are
here is the sequence for the rear windows: (do for each window using front controls )
1)Fully close the window and hold the window switch in the close position for 2 seconds
2)move the window all the way down and then hold the window switch in the down position for 20 seconds
3)Close the widow again and hold the switch in the up position
4)While holding the window should now move all the way down and then up by itself to show its been initilized
5) Let go and hopefually all is well
For the front windows :
1) fully close the front window and hold the switch in the up position for 2 seconds
Old Jul 10, 2005 | 05:32 AM
g8r's Avatar
g8r
[snapback]147544[/snapback]
Wow. I just tried this and it worked. Thanks E60 Speed!
Old Jul 10, 2005 | 06:35 AM
E60Speed's Avatar
Originally Posted by g8r' date='Jul 10 2005, 08:32 AM
[quote name='E60Speed' date='Jul 10 2005, 09:24 AM']maybe you guys should try to re-initilize the window (teach the anti trap where the fully closed and open positions are
[snapback]147546[/snapback]
[/quote]
Great, keep us informed if it keeps working correctly
