Window only closes half way in automatic setting
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up!
04 545i all the goodies INCLUDING HEADACHES!
My passenger window only closes 1/2 way when I use the one touch close method. It will give me an error indication on the instrument cluster. If I hold the switch in the close position it will close all the way. This happens using either the drivers or passenger switch.
Is there any way to reset the memory so it will close fully using the auto method? I though I read it somewhere in a forum but I can't find it again.
My Ride: G30 M550i
Model Year: 2018
You'll be fine after trying one of the procedures outlined here:
https://5series.net/forums/topic/258...nti-trap-reset
TexaZ3
05-06-2015 09:54 AM
rackhacker9275
26
04-16-2015 08:13 AM
