will my 19's fit on a 06 330i
My Ride: READY TO RACE ANY TIME? LOL
Originally Posted by Alpine White Girl' post='873021' date='May 8 2009, 08:58 PM
yes.
Originally Posted by kenmasterlegend' post='873020' date='May 8 2009, 07:57 PM
I want to know if my 19's csl wheel will fit on a 330i?
Originally Posted by mjfloyd1' post='873027' date='May 8 2009, 09:06 PM
Assuming the 19 inch CSL's are on a non all wheel drive 5 series, then the offsets are wrong and the wheel will stick out of the wheel well too far. If they are on a all wheel drive 5 series they'll be tucked in the wheel well a bit, but will be better than the 5 series "I" wheels on a 3 series.
Originally Posted by kenmasterlegend' post='873034' date='May 8 2009, 08:10 PM
Like how far out u talkin about cause i want to sell my wheel to him so I can get some MHT wheel
What vehicle are the csl's on? XI or I
Originally Posted by kenmasterlegend' post='873042' date='May 8 2009, 08:15 PM
545i
3 series offsets are 34 front and 37 rear.
They would stick out (34-12)= 22mm front so just shy of an inch
They would stick out (37-20)= 17mm rear so about three quarters of an inch
As is, the fronts would look goofy, I suspect. The rears would probably be OK.
If the rims are the same size all around ( non staggered or each wheel is the same width), you could try the rears with the higher offset on the front of the 3 series and it would stick out about 14 mm or just a little more than a half inch, and the fronts on the rear of the 3 series would stick out about 15mm which is also a little more than a half inch. If the rears are wider than the fronts (staggered), this won't work though.
Are the wheels staggered?
Originally Posted by mjfloyd1' post='873049' date='May 8 2009, 09:24 PM
Offsets are about 12 front and 20 rear on the 545i wheels.
Originally Posted by kenmasterlegend' post='873050' date='May 8 2009, 09:27 PM
yes they are
The 5 series XI has about the same offsets as a 3 series (actually a little higher offsets than the 3 series). Look up member "DAS", he has a 5 series XI and he put I wheels on it. The front tires stick out past the front wheel well and it looks odd to my eye. But the guy you are selling them to might like it, who knows.
