Will a 255/35R20 & 295/30R20 fit - wheels 20x8.5 & 20x10 et20
My Ride: 07 550i
I am about to purchase a set of wheels for my 07 550i and am looking at a set of Eurotek U06's in a 20x8.5 (front) & 20x10 (rear) with an offset of 20mm.
Tire wise, I am hoping to go with a 255/35R20 (front) and 295/30R20 (rear), most likely the Toyo Proxes 4 Plus. I do not like the stretched look and the girl drives my car so I need as much wheel lip protection as possible. I am aware of the increased overall diameter and speedo difference, but these tires should put me dead on since my speedo is off by 3 mph.
With the above in mind, do you think these wheels/tires will fit with no rubbing issues? I am lowered on coilovers so I can raise the car and/or lower if needed, and the front fenders look to be rolled (purchased car used), but am unsure.
Thanks in advance,
Dave
Thanks in advance,
Dave
My Ride: 07 550i
According to the online tire and wheel offset calculators, the above setup should work. Just went out and jacked up the car and took measurements and all looks good. Front going to be a tight squeeze, possibly slight touching on plastic fender liner during tight turns. In rear, just need to roll the fender lips and should easily clear.
If anyone wants to chime in, that would be great.
Virak1985
06-16-2015 12:24 AM
BrandonSS
03-13-2015 12:19 PM
