5Series.net - Forums
-   -   Wierd Start Up Problem!! (https://5series.net/forums/e60-discussion-2/wierd-start-up-problem-78159/)
tango3 May 31, 2009 10:31 AM
Today when the car started up all the icons were flashing for like 1-2 sec and the engine sounded like it was about to die or something. It started then died started died and then finally started up. And now evertime i start the car the clock resets. Whys is this?!?!? :o
kxmills May 31, 2009 10:40 AM
Battery? :confused:
EBMCS03 May 31, 2009 10:56 AM
Battery!
JasonH May 31, 2009 11:00 AM
I'd check the battery volts.
The car will start with some very low volts but the electronics hate it.
Below 12.0V and it's definitely the battery. A good battery will be 12.5V+.
tango3 May 31, 2009 11:33 AM
Thanks I'll check the battery
tango3 Jun 1, 2009 08:17 AM
OH No the car wont start now. When you try yo start it the headlight keeps flashing and the engine just sounds like tack tack tack tack tack tack.
etchu Jun 1, 2009 08:50 AM
how old is your car?
Allan_K Jun 1, 2009 09:17 AM
should be battery, but in that case you should also have on your OBC a fault notice(battery sign) about that.
tango3 Jun 1, 2009 09:26 AM
We jump started the car and now it works
I saw an engine light that said something emission
Allan_K Jun 1, 2009 09:33 AM
in that case just recharge the battery
