Why are my lights moving
Old Aug 11, 2006 | 09:28 AM
cliffysa's Avatar
My Ride: E60 523i silver, black leather , sunroof , bluetooth , pdc , M sports kit , Steptronic gear box , active stearing , active cruise control
HI guys
Every time I switch on my car and my auto lights come on they move about 5cm up and then 5 cm down then level out again if i had the xeons i would not question it but the thing is that I dont so why is it doing this
Old Aug 11, 2006 | 09:45 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Autoleveling.
Old Aug 11, 2006 | 09:47 AM
cliffysa's Avatar
so what does it do
Old Aug 11, 2006 | 09:48 AM
Iceman's Avatar
Model Year: 2013
It makes sure you're lights are even.
Old Aug 11, 2006 | 09:52 AM
cliffysa's Avatar
oh ok thanks iceman also one more thingh i have steptronic right and when i put my car into park should i use the handbrake aswell
Old Aug 11, 2006 | 09:55 AM
Iceman's Avatar
Model Year: 2013
I allways use it, but others never do so.
Some ppl call it parking brake, some emergency brake.
To me it is a parking brake and I allways use it when I park the car. That is the main purpose of it.
Old Aug 11, 2006 | 09:58 AM
cliffysa's Avatar
because in the owners manual it says nothing about using the parking brake when you are parked but shorely this can damage the gearbox?
Old Aug 11, 2006 | 10:01 AM
Iceman's Avatar
Model Year: 2013
Originally Posted by cliffysa' post='321569' date='Aug 11 2006, 07:58 PM
... this can damage the gearbox?
The parking brake? No.
IF something damages the gearbox then it would more likely be the P only without parking brake, but this will also not damage the gearbox.
Old Aug 11, 2006 | 10:11 AM
525iSE's Avatar
Sometimes you find that if you don't use the hand brake, after you park, when you shift back from P, you hear like a crank sound and you feel it too. In the long run, it could damage your gear box, so I recommend, when you want to park, after you come to a complete stop, move your gear to N then apply the hand brake, then put it into P. This will avoid the crank sound and will make your gear box last much longer. Also, it keeps the hand brake readily available when you need it. If you don't use the hand brake at all, after awhile you'll find that the hand brake doesn't work like its suppose too, usually it'll "fail".
Old Aug 11, 2006 | 10:26 AM
cliffysa's Avatar
[quote name='525iSE' date='Aug 11 2006, 01:11 PM' post='321576']
#, you hear like a crank sound and you feel it too. In the long run, it could damage your gear box,
yeah thats what i was felling when I put it into park so I will do the netrual thing today thanks 525ise and iceman
