Why isthe 530i SMG faster vs. Step version
My Ride: Soon to be 2005 5-series
Why is it that the 530i SMG transmission car is .3 sec faster than the Step. transmission car? The both weigh the same. Is it in the speed of the shifting of the SMG is similar to the manual?
From www.bmwusa.com:
Weight 1 Unladen
Manual transmission 3461 lbs Unladen
Sequential Manual Gearbox (SMG) 3483 lbs Unladen
Automatic transmission 3483 lbs
Weight distribution, front/rear
Manual transmission 50.4/49.6 % Weight distribution, front/rear
Sequential Manual Gearbox (SMG) 50.4/49.6 % Weight distribution, front/rear
Automatic transmission 50.9/49.1 %
Acceleration 0-60 mph - Manual Transmission or SMG 6.6 sec
Acceleration 0-60 mph - Automatic Transmission 6.9 sec
Weight 1 Unladen
Originally Posted by heezy545i' date='Dec 14 2004, 04:57 PM
speed of shifts and torque converter?
[snapback]69136[/snapback]
What's also puzzeling is that the weight of the SMG is identical to the Step. but the weight distribution is the same as the manual trans?
My Ride: G30 M550i
Model Year: 2018
It's all about the torque converter. Manuals (no torque converter) transmit more of the available power to the driveshaft. Automatics (with torque converter) always rob you of some of the power. It's the nature of an automatic.
Remember that the SMG gearbox is identical to that of the 6-speed manual. It's the clutch that's different...
My Ride: G30 M550i
Model Year: 2018
Originally Posted by a061444' date='Dec 15 2004, 03:07 AM
But, how do you explain the weight distribution?? Where did the weight go up, front and rear?
[snapback]69244[/snapback]
