why does my car sputter and snort like a fat pig when i first start it
Old Apr 22, 2010 | 07:34 PM
e6t's Avatar
e6t
after about 10 or so seconds it settles down... but sometimes, its pretty rough and I wonder if it is going to stall.
normal? what say ye?
Old Apr 22, 2010 | 10:27 PM
John@Motorcepts's Avatar
Banned
My Ride: A Car
mebbe ur plugs? It happened to me too but it went away. I bought some plugs but didnt change it yet. Or mebbe use some fuel injector cleaners
Old Apr 22, 2010 | 10:43 PM
yellowmountain's Avatar
Could be ignition coils kaput. Seems common over here. Check that.
Old Apr 22, 2010 | 11:42 PM
spinitch's Avatar
My Ride: 2005 530i Premium Package
Bad fuel? How often does it do it?
Old Apr 23, 2010 | 06:25 AM
juniordriver545i's Avatar
My Ride: e60 545i 2003, going for executive style
i actually have exactly the same problem, and just a couple of days ago I had full engine oil service (i.e. drained and filter changes) and I had new spark plugs put in. i also had full interim service. this did NOT solve this problem when u first start the engine. I have noticed though that the engine noise has become very quiet and smooth , and gear changes improved . So if there is a solution it aint spark plugs or oil change.
Old Apr 23, 2010 | 06:26 AM
fuel could be the reason, will test next week, but i realy doubt as I already mix 95 and 98 grades anyway.
Old Apr 23, 2010 | 07:32 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
You have a 535i.... search for cold start issues or here is a shock, HPFP issues.
Old Apr 23, 2010 | 07:44 AM
lilazngrl4o8's Avatar
My Ride: 04 545i Jet Blk, Blk Int, SMG, Sport, Nav, Prem, CW Pack, L7, PDC
I get that sometimes in my car. When I go to turn the key and crank the car, it sputters for like 1-2 seconds then fires up. Sometimes when I turn the key, it fires up fine w/o any sputters. Doesn't snort though lol.
I've come to learn that if I shut off all my electronics in the car (radio, ac, heated seats and steering wheel) and let the engine run for a few seconds while everything is turned off before turning the car off, the next time I go to crank the car, it's smooth. However, if I turn the car off with something still running, I can almost guarantee the next time I go to turn it on again it'll hesitate for like 2 seconds and then fire up.
weird.
Old Apr 23, 2010 | 09:27 AM
DD_545i's Avatar
I was having that occasionally (maybe 1 in 5 starts) until I got my battery replaced. Since then, it hasn't happened ever again.
Old Apr 23, 2010 | 10:04 AM
cmoore_'s Avatar
My Ride: 545i/6
Ive noticed when I let go of the "start" position on my instincs the car stutters for a few seconds on start up. Try holding your key in the "start" position an half second longer than you normally would. Seems to give me a smooth start up everytime.
