why does my car sounds like a cricket at idle?
Old 11-25-2009, 06:54 AM
e6t
e6t's Avatar
i've noticed lately that there is a subtle chirping sound coming from the engine compartment when my car is at idle... it is very noticeable when i am in a drive through...
anyone heard something like this?
Old 11-25-2009, 09:01 AM
ADD
ADD's Avatar
I've heard it periodically, but it usually goes away if I rev the engine.
Probably a belt or pulley. It is constant?
Do you spray down your engine bay to clean it?
Old 11-25-2009, 11:47 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
535i right....
EDIT:
Waste gate chatter and HPFP working ( HPFP is a prop shaft driven mechanical fuel pump). Normally you can hear it at low-er RPMS ( under 3500RPM) . Gets very apparent around walls where sound can echo.
Indicative if the N54 design.
The Waste gates articulation arms/valves don't do a good job shutting /seating the flap. So it flutters. Some of the solutions from BMW have only been temporary fixes: Software reprogram , to them being open at low rpm ( Lag) , Replacement ( comes back), replacement with new Turbos ( come back again), Adjustment of arm timing ( helps but come back), new Seat ( comes back).
I don't think I've seen a remedy...
Also may hear a metallic PINGPINGPing, like a bolt dropped in a blender.....
If it is not the engine could be the HVAC or a fan
I might need to make a sticky on the N54.. seeing a lot of common questions in the past two weeks on them.
TexaZ3
04-08-2015 10:50 AM
Stranger12
04-05-2015 10:42 AM
Sic Sticks
03-30-2015 01:17 PM
james69z28
03-23-2015 06:45 PM
08-12-2003 11:41 AM
Quick Reply: why does my car sounds like a cricket at idle?
