Why am I getting such horrible gas milage?
Hi i have a 2004 545i, and atm im getting around 12 mpg, so far ive cleaned my air filter (have a k&n on the way) , ran some seafoam though my oil and then changed it, new oil filter, new spark plugs, put some seafoam in the gas to clean the fuel injectors, and ran some seafoam though the vacum line. helped a little, before i was at around 8-10 mpg.i use 92 gas, i drive very easy , barely ever push it, i live in a very flat land area, no hills.my father did say he notice an unusual smell of gasoline coming from the exhaust. also the car does smoke from the exhaust a bit, its gotten better, but last time my friend reved it , a cloud of smoke shot out of the exhaust. the car idles fine an sounds good, there is a little clicking sound at the engine, but im pretty sure thats because i just changed the oil. also i did notice a weird sound come from under the car ( under the car on the driver side near the exhaust) its sounds like a high pitch buzzing sound jus like when u turn on HID lights. also, i just remembered, about 4 days ago, the check engine light went on, i scanned it an it said P1890 . cleared the code and it never came back.im starting to think that it may be the catalytic converter, would make sense because of the smell from the exhaust, also once a rev it a huge build up of smoke just shoots out as if its clogged or something, an also, when i turn on the heat, its not very strong, (experience from another car, the car was not shooting out any heat when i would turn on the heat, as soon as i changed the catalytic converter, the heat an air was much stronger in the car) . an lastly, when im driving, an i let go of the gas so the car can roll, its feels as if the car is being forcefully being slowed down as if im down shifting in a manual car, but my car is auto, my guess is the car is being restricted from breathing from the cat, but im a newbie, so if anyone has a better suggestion, please do say. i did a little more research an found out that a bad thermostat may cause unburned fuel and obviously a lack of heat for the heater
sorry for the long post, i had a thread going on before, but it kinda died out
My Ride: 2006 BMW 530I
Model Year: 530i
Maybe it's normal? I bought and own my 2006 530i since it had 4 miles on it. From day one, I have often averaged 18.9 miles per gallon. It's a V6, automatic.
Sorry if I am not giving you the answer you want to hear.
I don't have this vehicle, but I have an X5 4.4i that's consistently around 17, half city. Given that, with a big, heavy AWD, I wouldn't think 12 sounds normal, I always thought that was more like M5 consumption. Not sure what to look at to diagnose, though.
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
That isn't normal. I get about 19 in mixed driving with the same engine. It will probably save you some money to get it diagnosed properly by an indy shop, rather than throwing parts at it, although my first guess would be it's not warming up properly due to a bad thermostat.
After it's fixed, you might want to take it for a little scream down a long straight road to blow some of that carbon away. Have some fun, and red-line it a few times! That's what it was built for.
agreed with above, i have an 07 550i and i get (normal driving ) 18 in city and doing 70-80mph 24-26 highway so you have somthign going on. first what's milage and i tend to agree with thermostat issue. if car doesn't see the right temp level will keep car running rich
My Ride: 04 545i - Titanium Silver/Black, Sport pkg, Comfort Seats w/ Lumbar, Premium Sound, power rear sunshade, Adaptive Xenon Headlights, Steptronic, Park Distance Control, Fold down rear seats w/ski bag, Aux jack, 6-disk changer, puddle lamps...
Engine: Custom Remus cat-back exhaust w/chrome square tips, K&N Air Filter, Charcoal Filter Removed, Sprint Booster :-), 50/50 mix of 91+100 Octane, EuroRev ECU Remap (coming soon lol), Dinan High-Flow Throttle Body (coming soon...maybe lol)
Interior: Portable Sirius Stilletto 100 w/car kit, Garmin Nuvi 680 mounted below rear-view mirror, LCI-style I-drive knob, Dark Poplar Center Dashboard Trim.
Exterior: E60 forum clings, 5% rear tint, ACS roof spoiler (painted black for distinct look against limo tint), ACS trunk spoiler, ACS add-on front spoiler and rear apron (awaiting installation), "18 Black Staggered BeBeS Style OER (emergency replacement for cracked sport 124 rims), black kidney grill, white accessory lighting (including license and trunk lamps), Angel-eye upgrade, AIB xenon-matched fog lamps, AIB V3's on order, red rear reflectors
I'm in SoCal and commute home in some of the worst traffic in the country (101/405 freeways). I average around 17 in my 545i. Again, as stated on the prior thread have your exhaust system checked for restrictions. The thermostat can also be checked with any scan tool that has PID maps.
If you're smelling exhaust, you are dealing with
1) Unburned fuel. Coil packs/spark plugs should be checked for faults/replaced. Especially plugs.
2) Failing catalyst - clogged catalytic converters will sap mileage quickly
3) Faulty O2 sensors - will lead to 1 and 2
4) Faulty fuel sending unit
5) Vacuum leak
6) Failure of fuel vapor recovery system. Allowing fuel vapors to escape.
7) Fuel system leak
"Sticky" brakes, etc. could also be causal. Best thing to do is to put it in the shop for diagnosis.
5) Vacuum leak
7) Fuel system leak
5) Vacuum leak
7) Fuel system leak
5) Vacuum leak
7) Fuel system leak
he suggested i manually calculate the mpg im getting, he also said that i should buy a fuel injector cleaner and pour a quarter of it when the tank is near empty, and do this 4 times after every time the tank is near low. he did notice a smell from the exhaust though while donig the emissions test.
but im going to calculate it manually and put some more fuel injector cleaner.
if anyone has anymore suggestions as to what might be causing this poor gas mileage, please go ahead, thanks for the replies guys
You mentioned a heater warm-up issue. It's possible your car isn't reaching the proper operating temperatures - running cold will greatly reduce your fuel economy.
well according to the temperature gauge it seems as if its functioning, like in the morning i can see it move down as the car warms up.
