White Splatter In My Engine Bay
My Ride: 2012 535i xdrive M-Sport Dark Graphite II 2004 545i Black Sapphire Metallic-Retired 2001 525i Titanium Silver Metallic-Retired1994 325ic Convertible Boston Green-Retired 1985 325es Dolphin Grey-Retired
Originally Posted by luigi524td' post='911136' date='Jun 14 2009, 07:19 AM
+1 Coolant spray dries into a white residue and it doesn't take much! Check levels and get a pressure test so that you don't get a warning when it's too late!
Another easy technique I've used to detect leaks, clean the area up, let it dry, then 'dust' the hoses, joints and other likely leak areas with talcum powder. Let the engine idle for a while and look for teltale signs of leakage - the white talc will track even the tiniest. Just don't race the engine or it'll blow off.
+2 It's def coolant. I had the same problem and it turned out the expansion tank hose was no good. I think it runs on top of the radiator. On that side around where the air box is a connection. You may have a leak at the hose connection point.
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
![Noexpression](https://5series.net/forums/images/smilies/imported/noexpression.gif)
My Ride: BMW 535xi
Remove all of the white deposits with water and mild soap. See if it returns. If it does, then it is a coolant leak. If it does not, then it was the fluid you used when you "detailed" your engine a few weeks back.
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
I had the same issue with my old E36 and the dealer traced it back to the water pump. They replaced the water pump, cleaned the bay and never saw the stuff again. Hope this helps.
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
