White Smoke Coming from Exhaust???
My Ride: 2004 545i: Silver Grey Metallic | Sports Package | | Cold Weather Package | Navigation | Tinted Windows | Adaptive Headlights | Heated rear seats| 166 rims| Matte black kidney grills|
Interior: Angel Eyes, LED license plate bulbs, HID fogs, Interior LED
Fellas.... I"m looking for feedback, I have a 2004 545i, I'm getting alot smelly white smoke coming from exhaust and I'm also using alot of oil.... any ideas what the cause is and if so what needs to be done to correct issue? I'm thinking the cause is the heads.... any feedback welcome
My Ride: BMW 545i CSR
Not necessarily. I had no smoke, but a lot of oil burning. I changed some parts in the engine - oil gaskets I think. 700 euro job. That's about a 1000 usd.
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
White smoke in the exhaust is caused by oil and water mixing somewhere in the ignition cycle. It can be as simple and cheap as replacing the head gasket or a nightmare and expensive as a crack in one of the cylinders or the head itself!
Thanks for the feedback fellas
hi,
do you have the "check engine" message activated on your I drive or dash board?before going through crank repair,check the breather valve.The same has happened to my 530i,2004.white smoke,rpm fluctuating at idle.....
hope it helps
hope it helps
BigxPx
04-23-2015 10:11 AM
thesalboy
04-08-2015 09:13 AM
