White excessive exhaust smoke- Good/Bad?
Old 03-01-2009, 09:28 AM
flyingpuck's Avatar
If you are serious about this car, then you should DEMAND a compression test!
Old 03-01-2009, 02:23 PM
craigm1841's Avatar
white smoke with a sweet smell means bad head gasket or worse, warped heads. I am still confused by the original question. White smoke good or bad? I dont know of a single scenario where any kind of smoke is good, unless you are a smoker.
i would NOT get this car just to be safe. the current owner should get the warranty work done, rather than passing it on to you
Old 03-01-2009, 03:41 PM
diplo's Avatar
So what about the video clip, does that look okay? I think i used the wrong term in my original post, its not smoke, more just condensation.
Old 03-01-2009, 03:50 PM
luigi524td's Avatar
+ 1 ... accompanied by a pressure test of the cooling system.
Old 03-01-2009, 04:34 PM
dropped545's Avatar
the smoke in the video is condensation that is normal esp in cold climates,u should be ok..i saw a 745 in front of me at the light take off and it had blue smoke thats when u start worrying,other then that your ok...good luck...
Old 03-02-2009, 03:20 PM
diplo's Avatar
thanks, thats reassuring. Pretty much that video is exactly how it is. Ill probably be posting in the introduction thread soon. Thanks guys for the feedback.
tundra
11-10-2016 06:55 AM
PelicanParts.com
07-23-2015 12:50 PM
pantzjantz
07-07-2015 04:44 PM
gray545i
07-06-2015 03:54 PM
Quick Reply: White excessive exhaust smoke- Good/Bad?
