While idling, engine of 550i (2006) occasionally rocks
#21
My Ride: 2007 550i. Sapphire Black Metallic/Auburn Leather/Anthracite trim. Sport/Comfort Access/Navigation/Satellite/HD Radio/HUD/Premium Sound/M Aero Kit/with 50% tint sides & rear. 19" Style 166s.
I was told it was normal when taking delivery. It's really no problem as it only lasts a few seconds. These high powered V8s with computer controls are great. They adjust themselves to smooth it out based on the current conditions.
Personally, the TSB suggests some internal repairs that scare me. "If it ain't broke, don't fix it". I'd be afraid to go poking around in the engine just to solve a few seconds of rough idle, that isn't hurting anything. You've be "poking the bear"
Besides, I love it. It reminds me of our old high performance Detroit muscle car V8s with a high performance cam!! Brief, but wonderful flashbacks!!
Just consider it as waking the beast up. He's a little grumpy 'til he get's his act together. Then...HANG ON BOYS!!! WooHoo!!!
Have fun guys.
Have fun guys.
#22
Have fun guys.
Have fun guys.
The symptoms members describe here (including mine) can go well beyond that, however. The idle issue described in the SIB's can create extended vibration that actually causes the car to rock and sound like a older diesel engine. This can happen after warm up, and also created surging that made driving at low speed in very slow traffic very difficult (freeway on ramp with a meter light for example), again the car would rock and would surge forward, making low speed difficult to modulate with the throttle. After the injectors were replaced, however, mine behaved exactly like yours, which is why I keep laboring the point.
#24
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron"
SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR
2003 Audi A4 3.0 CVT "Part of the Moniker"
Silver/Ebony, Prem, CW, Star 17s
Originally Posted by swajames' post='468144' date='Sep 10 2007, 10:55 PM
Nope. Excessive roughness on idle with an N62TU is not "normal", and it does those owners who have these problems a disservice to claim it is. The factory rep from BMWNA confirmed that there are known idle issues on some of these units and also its predecessor in the 545. In my case it was actually the BMWNA factory rep who came up with the fix (injector replacement) that had eluded the otherwise excellent efforts of my dealer. There are also TSB's confirming how to address idle issues on the 545/550 - so it appears that BMW also acknowledges the issue and has determined how to deal with it.
"Excessive roughness" is the key word here. N62TU has a rough idle, but the "excessive" intepretation is not widespread on this forum. Its argubly a disservice to panic posters on what is a common trait of the motor, and to assume they are at risk to injector replacement. Maybe the correct advice sounds like this, "the idle issue is common to the V8 E60, but most owners have had little problems with this. To be on the safe side which is your decision, bring your E60 in for service and have the SA inspect the engine and go thru TSB."
Your injector replacement didn't solve rough idle on your E60 and we haven't seen many posts here about injector replacement. It is your impression that the TSB will completely address the rough idle issue? (both mild and excessive)
So the N62TU sounds like a Lexus V8?
CVT Benhogan
#25
My Ride: 2004 545i with 325HP 6 speed Steptronic trans with DVD NAV, Heads Up Display, Logic7 sound system, Rear sunshade, Sport Package....
1600 - Do know the version of software they used to fix this issue.
#26
CVT Benhogan
CVT Benhogan
BTW - I've got no problem with a rough idle per se. The idle on my 997 is as rough as a hedgehog's a$$ but it's meant to be that way and I absolutely love it. With my particular N62 it was pretty clear from the outset that it wasn't as it should be.
Anyway - I suspect we're saying the same thing. Roughness per se is no big deal, if it's excessive get it looked at.
#27
My Ride: Fully Loaded Monaco Blue 550i Sport
I'll check in...
I have a 550i and i get a very rough idle upon start up after the car has been sitting for awhile... within less then a minute it goes away and everything is as smooth as a babys ass
#28
I know some of us think ?a little roughness? is normal. I don?t buy that. I bought a car for 50+K, not a school bus. If dealer is not able to take care during my next visit, I will go for lemon law.
#29
My Ride: 2008 Sapphire Black on Black M5 - loaded sans soft close doors
It is not normal - what you are talking about is the occasional bump while sitting at a light correct? Where the engine basically mis-fires correct?
Friend had it on his X5 - they replaced the heads (got better) but it was never perfect. He got rid of the car it was so annoying.
So it happens a lot on the 4.4 and 4.8 engines, is not normal, and should be fixed.
