Sponsored by:
Sponsored by:
Where is the transmission fill plug?
Old 12-28-2013, 03:02 PM
My Ride: 2006 530xi touring
Engine: 3 liter
Default Where is the transmission fill plug?
Have you wondered, done a search and found nothing? Here is to help you out.
The fill plug on a 2006 BMW 530xi AWD is at the left rear corner of the transmission, 1 inch above the gasket line. It is obscured totally by the coupling drive shaft from the gear box to the front 2 wheels. It needs 8mm allen socket. In order to get access to this plug, you need to remove the 4 torx bolts and let the coupling gear hang down.
A picture says a thousand words.
yelcab2 is offline
Old 12-28-2013, 09:00 PM
My Ride: 2008 528xi (Silver)
hey, i been trying to tackle this last week with no luck, and thought it was a stealer job only, i obviously came back with 860+ quote. I still would like to do this myself, could you tell me if you need a impact to remove the drive shaft screw for the front wheels.
e60rider is offline
Old 12-29-2013, 02:53 AM
Engine: 3 liter
No impact is needed. You need a set of torx sockets, and some wobble extensions. The four torx bolts are not on there that tight. Remove one end and let it hang down.
yelcab2 is offline
chadillac2000
E60 Parts, Accessories and Mods
42
09-13-2017 11:15 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
nathanhun
05-08-2015 04:04 AM
pcy
04-13-2015 02:53 PM
BYS2
04-08-2015 06:16 PM
Quick Reply: Where is the transmission fill plug?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
