Where do all the relais sit?
My Ride: 750i
Model Year: 2014
I'm looking for the cooling fan relay.
I found one realay each in the glove box fuse box and the rear trunk fuse box. That is it. None of them are for the cooling fan.
So, where are rest of them?
My Ride: 540i
Model Year: 2017
http://www.bmw-planet.com/diagrams/r...0e61/index.htm
Electric Fan
Under certain operating conditions, the engine control activates the electric fan at various speeds.
The electric fan is activated by means of a power output stage directly on the fan motor. The motor control unit activates this power output stage by means of a square-wave signal with duty factors (variable pulse width) between 10 and 90 % thus controlling the various speeds of the electric fan. Pulse duty factors less than 5 % and greater than 95 % do not trigger activation but rather they are used for fault detection purposes. The power output stage features its own positive and ground supply.
The fan speed is influenced by the coolant temperature at the radiator outlet and the pressure in the air conditioning system. The fan speed is reduced as the vehicle speed increases.
Here's a pic of a bad fan motor driver,
My Ride: 750i
Model Year: 2014
Thank you for posting this information. Is it fair to assume that my fan is fried then? Or could it be a temperature sensor on the motor after all?
Then, I am certain the fan is dead. You will need to get a new fan. Call around - prices differ from dealer to dealer and on-line parts places as well.
My Ride: 540i
Model Year: 2017
pcy may be correct about your fan. Checking further with a voltmeter, reading error codes, or substitution is your next DIY step(s).
Florida2002m3
09-01-2015 10:59 AM
