Wheels slanting outwards?
Old 05-16-2009, 08:53 PM
NextLevel530xi's Avatar
Hey Guys... Finally just got my car back from the dealership getting new front tie rods. Got a alignment done due to the fact that I just installed H&R springs on my baby. Was having a smoke while staring at the car and noticed that my rear wheels are slanting outwards on the bottom and somewhat inwards on the top? Is this normal? I have 275 running on the rear and 245 in the fornt.
Old 05-16-2009, 08:56 PM
sc88's Avatar
My Ride: 10 X5 35d AW/Blk LOADED
Yup!
Normal toe out camber. Helps with cornering and comes like that factory.
I think by dropping a car it becomes more noticeable.
Post pics of the car!
Old 05-16-2009, 08:58 PM
CWS530's Avatar
A -2 camber is BMW spec on the e60. Sure you're fine.
Old 05-16-2009, 09:04 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Do a search here using the terms 'negative' and 'camber' and you'll learn a bunch more...
Old 05-16-2009, 09:29 PM
Been making a write up of the new set up of the car. Especially for the xi owners. Put on 19'' miro m6 time attack reps, hamman front splitter, acs quad style diffuser (made a copy of the broken one I paid Eurorev). :thumbsdown: Quad remus exhaust. Resanator deleted. Black 530xi emblem. H&R lowering springs. Stainless steel racing strut bar. 8000k HIDS top and bottom from Erick from Elite motorsport . When I find time will finish and post up. Thanx for the info about the rears tilting outwards. Though I screwed up my car up. Phew..
Old 05-16-2009, 09:37 PM
DrLev99's Avatar
As long as it was aligned correctly, it should have -2.00 degrees of camber in the rear...as per spec. I'd know since I had my xi aligned about 4 times and watched each time.
Does it look like this? My old xi with H&R's.
Old 05-16-2009, 11:34 PM
+1, even the stock wheels on stock suspension there should be negative camber
Old 05-17-2009, 04:56 AM
CWS530's Avatar
Is there an echo in here...in here...in here?
Old 05-17-2009, 06:12 AM
melimel's Avatar
+1...
Old 05-17-2009, 06:35 AM
06530-6M's Avatar
Post
I'm not entirely 100% sure, but I think the E60 is supposed to have a -2 camber in the back. I'll research this and get back with you!
Sorry, had to ...
Quick Reply: Wheels slanting outwards?
