Wheels...
Old Dec 28, 2008 | 07:42 PM
C's Bimmer's Avatar
Originally Posted by iCharles' post='754658' date='Dec 28 2008, 11:33 PM
It's what I was always told with my A4 Quattro. Maybe it's a myth, but when I was putting 19's on it everyone said stay away, something about potential damage to the transfer case. Perhaps technology has evolved since then, good news!
The reason for the same width tires at all 4 corners on an AWD car, such as the Audi, is that it assumes that you'll be driving the car in wintery conditions. That said, it's ideal to have the same width of tires at all 4 corners for these conditions in mind (i.e., snow).
Take my current car for example... I'm running 255/40/19's at all 4 corners with my Blizzak LM-22's on my stock, 166 wheels. Come summer, I have my 20" wheels that are of course, staggered (255 & 285). If you are going to run 2 sets of wheels/tires for the various seasons, then running staggered on the E60xi is fine for summer and dry conditions. If you live in a place that has snow, then getting a second set for winter (with the same width for all four), is ideal.
You just need to get a wheel that has a high offset. The best wheels to look at, if you are an E60xi owner, are the 3 series wheels (E46 or E90). And when I say 3 series wheels, I'm talking about the standard, RWD 3 series wheel (not the 3 series XI wheels ). The standard, 3 series, RWD wheels have high offsets (ET 35+).
Here's another tool to use, for calculating offsets:
http://www.1010tires.com/WheelOffsetCalculator.asp
And here are all the wheels for the 535xi made by BMW. If you click on each wheel, you will find the exact specs (width and offset). The standard offset on the E60xi is ET43.
http://www.realoem.com/bmw/partgrp.do?mode...hg=36&fg=15
Unless of course, you run the 124's, which are staggered and made for the E60xi. Those rears are ET55 with a 9" width, while the front is ET43 and a 8" width.
http://www.realoem.com/bmw/showparts.do?mo...hg=36&fg=15
Old Dec 28, 2008 | 07:54 PM
C's Bimmer's Avatar
Check out this link:
Note the BMW OEM specs on the 124 wheel which is made SPECIFICALLY for the 535xi. This is a staggered set-up that BMW designed for the XI only. These offsets will not work on a RWD model.
Front: 18x8 ET43
Rear: 18x9 ET55
Tire
Front: 245/40/18
Rear: 275/35/18
Old Dec 28, 2008 | 07:58 PM
CWS530's Avatar
I think you are wise to make the switch. All those bolts and wheel shape just don't do the car justice IMHO.
Old Dec 28, 2008 | 08:04 PM
hdmyg85's Avatar
Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
Old Dec 28, 2008 | 08:11 PM
bmwvmi02's Avatar
My Ride: 2006 Titanium Silver 525xi
Too flashy for my taste. I agree with CWS530
Old Dec 28, 2008 | 08:13 PM
Gene's Avatar
+1K
Old Dec 28, 2008 | 08:14 PM
C's Bimmer's Avatar
I couldn't agree more!
Old Dec 28, 2008 | 08:33 PM
+1 for VMRs. PM replied btw
Old Dec 28, 2008 | 08:47 PM
EBMCS03's Avatar
Originally Posted by C's Bimmer' post='754653' date='Dec 28 2008, 08:24 PM
my new X5 4.8 Sport
Really? Lets see some pics... go post it in the "Other BMW" and link me.
Old Dec 28, 2008 | 08:55 PM
C's Bimmer's Avatar
It was custom ordered. It goes into production on Januray 19th. I'll get it the first or second week of February.
