Which wheel for winter?
Old Oct 16, 2007 | 10:13 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Ok fellows...
I?m concidering upgrading my winter tires and wheels from OEM 16" to aftermarket 17".
I?m quite sure what kind of wheels I would like to have: Dezent K 8x17 ET18
Only "but" thing with this wheel is that I?m forced to use hubcentric rings with it. 74,1mm -> 72,5mm.
The other (almost same looking) model is BBS?s wheel.
It?s hub is for e60 (72,5mm). 8x17 ET 20.
The question is which one should I go for? Do you see the using of hubcentric ring would be a problem anyhow? Both wheels are German as we know
The tire will be either Nokian Hakkapeliitta 5 or Michelin X-Ice North. 225/50 R17 is the size.
Old Oct 16, 2007 | 10:26 AM
s4iscool's Avatar
My Ride: E90 330i + E60 550i
i would never put a wheel on that required a ring...its just askin for trouble.
Old Oct 16, 2007 | 10:45 AM
Ricracing's Avatar
Dear Anzafin,
If the wheels aren't perfect, your E60 will not be either.
You need to have High Quality rims with perfect hub fittings!
I also recommend correct offsets (7,5x17 ET20).
Do not spoil your E60 with bad rims!
Up north in Finland Nokian Hakkapeliitta 5's with studs can't be wrong.
Old Oct 16, 2007 | 11:41 AM
E60BEEMER's Avatar
Post
bbs
no rings..!!
Old Oct 16, 2007 | 01:33 PM
joewatch's Avatar
I am starting to shop for winter wheels, also. I think correct fit is very important. Don't spend a lot of $$$ for rims that will be damaged cosmetically by sand and salt.
Old Oct 16, 2007 | 01:41 PM
joewatch's Avatar
I'm thinking of getting Borbet H for my winter wheel. The design looks like less snow will get caught in the wheel compared to other wheels with more spokes / wider spokes. This is the wheel recommended by tirerack. What do you guys think?
or :thumbsdown:
Old Oct 16, 2007 | 08:08 PM
slickrick's Avatar
My Ride: 2008 535xi / Platinum Grey / Black leather / Step Auto / Sport / Premium / Cold weather / 18" wheels / Logic 7 / Comfort / ipod / Navigation / Fold Down Rear Seats / Rear Airbags / Sirius SAT / Spoiler / Extended Clear bra / Bluetooth. (Previously owned a 2002 sport 525I Loaded). On order: 535xi Platnium Grey with Black interior, Step Auto, Sports package, Premium package, Cold weather package, 18" wheels, Logic 7, Comfort access, ipod adapt, Navigation, Sat radio, Rear spoiler, Extended Clear coat bra.
or :thumbsdown:
I'm also in the market for a winter setup. Don't likes these too much.
Old Oct 17, 2007 | 04:09 AM
s4iscool's Avatar
ive used borbets in the past for winter duty..they are cheap, but the style leaves much to be desired
Old Oct 17, 2007 | 07:14 AM
Anzafin's Avatar
Thank you everybody, I appreciate your input!
I chose the BBS as you advised and they're ordered now...
And what comes up about sand, salt and other things, I have had alloys for winter tires for years in my previous car (Toyota Avensis) and I never noticed any defects on them caused by winter use. They don't use much salt and sand here where I live. Streets in the town are usually sanded, that's true, but roads are usually clear. Only snow on them.
But yeah, I would not like to spend lots of €€€ for winter wheels. I rather put those €€€ for good winter tires
Old Oct 17, 2007 | 07:30 AM
Ceenit's Avatar
My Ride: 525
Great choice.
+1 on the BBS rims. I had BBS on my last 3 series and never had an issue.
I don't like adding rings either.
