5Series.net - Forums
-   -   Wheel question (https://5series.net/forums/e60-discussion-2/wheel-question-66064/)
wacopolumbo Nov 24, 2008 12:52 PM
A buddy of mine asked me and I didn't know, so I thought I would throw this out to you guys. He has some staggered 124 style rims. He can get a good deal on some 245 width tires. Can he put 245s on his back rims?
Thanks.
BrianTx5 Nov 24, 2008 02:58 PM
I have the original staggered 124 wheels on my car. The tires are 245/40/18 in the front and 275/35/18 in the rear. You can also check on Tirerack's website for other sizes that would work.
Tuti Nov 25, 2008 12:25 AM
Thanks.
I think you can. Even if the rims at the back are 1" wider.
The original 275 seem rather wide but they represents no problem in everyday use and provide traction in abundance. It also looks the part :D
TitangrauII530iA Nov 25, 2008 01:05 AM
Hi,
BMW OEM 124 wheels are available in two widths for rear axle, 8x18 and 9x18. If the wheels are 9x18, the only accepted tire is 275-35-18 tire. 245-40-18 tire on that wheel is illegal and does affect in driving as well because the wide wheel would set the tire in wrong position.
Here is a link to BMW Germany site: http://www.bmw.de/de/de/owners/accessories...der/finder.html where you can check this - in German language though.
Regards,
Jukka
Tuti Nov 25, 2008 01:11 AM
Aha!
There you have it, wacopolumbo:
9x18 rear rim: No go!
8x18 rear rim: Go!
mrfva Nov 25, 2008 04:15 AM
1 Attachment(s)
Thanks.
245/40/18 should work on the rear rim as well. But as others have mentioned
this may affect and change the normal handling of the car.
Based on the 245/40/18 specs for the Dunlop SP Sport 01 DSST RunOnFlat
from Tirerack.com, the acceptable rim width range is 8"-9.5".
Attachment 65799
Personally, I would not do it only because it changes the overall rim diameter
for the rear tires in comparison with the front tires.
wacopolumbo Nov 25, 2008 07:42 AM
Thanks guys,
We found out that the 245 (all brands) will work for rim widths of 8 - 9.5 inches.
Thanks again.
Ricracing Nov 25, 2008 10:21 AM
1 Attachment(s)
The 245's are OK (see pic).
OEM 8x17 ET 20 for 245/45R17 tires.
Also 225/50 tires will do, but then with "rim defense" tires.
Veight Nov 25, 2008 10:54 AM
Originally Posted by TitangrauII530iA' post='730822' date='Nov 25 2008, 05:05 AM
Hi,
Regards,
Jukka
I must disagree. I just put 4 ea 245 40r 18's dunlop winter sport 3D's on my staggered 124 wheels. There is no problem doing this. I called several tire shops before i did it and the 9 inch wheel is way with in the range for that tire. It drives fine.
MRV99 Nov 25, 2008 11:11 AM
I did the same, all 245's with my new Micheline Alpine sport's Just make sure that you that they put the 9" rims on the back. If you have them balanced, make sure you mention the rim width so they don't rotated the tires and end up 1 or both rear rims up front.
