Wheel change and all error lights appear
Old 09-25-2014, 06:40 AM
arctikz's Avatar
My Ride: 05 545i, 01 x5, 98 540i
Default Wheel change and all error lights appear
So im on my 2nd e60. Old one is a 2005 545i. I put 20" Beyern Multis on it and shortly after the first mile, i got a ASC, Brake, Stability, Active steering light. I drove like this for a few months and it eventually went away on its own. The brake would sometimes be red, sometimes be yellow. Active steering error light would come and go as well. But like i said, it disappeared one day and never came back..
Now i have transferred the wheels to a 2006 550i and i get the ASC light, Brake light, stability light, active steering, airbag light, seatbelt light, steering wheel lock warning, speedo doesnt work and odometer doesnt work but the tach works.. I really dont know why these lights have came about but the only thing i can think of is that the wheel size have made a sensor trip and now it needs calibrated. Ive searched the forums and google high and low and couldnt find anything or didnt know what to search for to find it. I dont want to wait 2 months for it to go away again.
Anybody have suggestions?
I have reset TPM, changed the battery, done the active steering reset, left battery disconnected for 2 hours and none of these worked
*update* The new tires are 245/30/20 and 275/35/20. Compared to the originals, the rear wheels are 7.9% taller then the stock wheels and front wheel are .5% bigger then stock with those tire dimensions. Would the larger diameter tire be whats throwing it off? If so, can i reprogram the car to accept the taller wheel?
*update* INPA codes pulled and all system errors reference a vehicle or wheel speed error. The 20" wheels have thrown off the wheel speed but how would i go about programming a wheel speed adjustment?
Here are the codes for the modules affected.
Active rollstabilization
d1f1 can message speed
d1df can speed vehicle
627a predve check:motor stopped during run
d1e4 can angle of steering wheel
Active steering
6139 vehicle reference speed or dirving direction unsicher or not verfuegbar
ce96 botschaft (wheel speeds, id=0CE) vom DSC F-can
ce98 botschaft (regulartin contact dsc_afs, id=11E) vom DSC F-can
CE9c botshaft (state DSC, id=19E) vom DSC PT-CAN
Dynamic statbility
5e5e wheel speed sensor general : general error while monitoring slip control (lamba)
5f62 - AFS: signal exchange AFS-DSC invalid
General Body Module - informatin memory
931A reset_weil_pdn
9312 fh_fth_block
930d FH_bfth_can_temperature_error
9310 FH_fth_can_temperatureerror
AirBag System
93FB speed-speed signal missing
steering column - information memory
274d synthetical steering angle unplausible
274e pt-waking unplausible
Engine n62
2c31 cdkftdla-lamba probe front catalyst, trimm control (stored from earlier)
29DD cdkswe - bad way detection (mentions wheel speed as well)
Transmission
51ad messeage (wheel speeds) from the dsc is missing (can-signal of a drivgn wheel is defective
Old 09-25-2014, 06:52 AM
sanjsanj's Avatar
My Ride: E60 530d
if you can put on some original wheels and see if the problem goes away.
Get your error codes read too.
Old 09-25-2014, 09:09 AM
arctikz's Avatar
Well the only that changed and made the lights come around was the wheel change so id assume changing them back would fix it. But its a long hard process for me with one jack.
Im going to get the inpa software installed on my computer and read codes and hopefully find something out but im not too familar with the program.
Old 09-25-2014, 02:20 PM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
What size tires are mounted on the 20's?
Old 09-27-2014, 11:51 AM
arctikz's Avatar
pulled the codes from inpa and Active steering, Airbag, Dynamic stability lights all have error codes at the same mileage point that read to be an invalid wheel speed detected. It seems that the 20" wheels have thrown off the vehicle speed so much that the sensors think there is an error. How would i fix this?? Can i code a wheel speed adjustment using ncsexpert?
The tires are 245/30/20 and 275/35/20. Compared to the originals, the rear wheels are 7.9% taller then the stock wheels and front wheel are .5% bigger then stock with those tire dimensions. Would the larger diameter tire be whats throwing it off? If so, can i reprogram the car to accept the taller wheel?
Old 09-27-2014, 12:47 PM
arctikz's Avatar
Active steering
Dynamic statbility
931A reset_weil_pdn
9312 fh_fth_block
AirBag System
Engine n62
Transmission
Old 09-28-2014, 01:10 AM
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
that would be your issues, on this staggered setup, you should have 245x35x20 and 275x30x20
the 2xx is the wide. but 3x is percentage of high taken from 2xx number.
so you have front wheels smaller circumferences than the rear and this is giving you the errors.
you have:
245 - 30% = 73.5mm
275 - 35% = 96.3mm
instead of this:
245 - 35% = 85.8mm
275 - 30% = 82.5mm
I'm afraid you will need new tyres to sort this out
Old 09-28-2014, 05:57 AM
twh
twh's Avatar
Engine: N52
See this reference https://5series.net/info/2006_5_Series_Manual_US.pdf, page 191. The permitted tire arrangements are listed. I used the tire calculator at www.discounttire.com/dtcs/infoTireMath.do to get the revolutions/mile.
245/40 R 18 -- 784.25 revolutions/mile
245/45 R 17 -- 785.33 revolutions/mile
225/50 R 17 -- 779.95 revolutions/mile
Front: 245/40 R 18 -- 784.25 revolutions/mile
Rear: 275/35 R 18 -- 788.47 revolutions/mile
Front: 245/35 R 19 -- 783.17 revolutions/mile
Rear: 275/30 R 19 -- 791.03 revolutions/mile
The setup you have yields:
245/30/20 -- 782.09 revolutions/mile
275/35/20 -- 731.29 revolutions/mile
Your rear setup is the problem. You need to get it to be something in the 780-790 revolutions/mile range.
Old 09-28-2014, 09:00 PM
arctikz's Avatar
so is 275/30/20 what i need to get or do i need to go even thinner?
Old 09-28-2014, 10:29 PM
Booyaazaa's Avatar
Yes 275/30-20 is the correct size for your rear tire to match your front.
Quick Reply: Wheel change and all error lights appear
