Whats the best shift RPM for best acceleration?
Originally Posted by aybeesea' post='373848' date='Jan 5 2007, 09:58 AM
A well-developed explanation but maybe TMI. When examiners mark papers they sometimes put "TO" against an answer meaning "Talked Out".
It's always great to try to illustrate answers to deliver meaning (and your post conveyed that extremely well as always) but using erroneous analogies doesn't aid erudition!
To simplify my particular point:
Torque and Force are not interchangeable physical entities. At the most basic, force is measured in Newtons (N) [lb wt] and Torque is Measured in NewtonMetres (Nm) [lb ft].
Particularly, F=ma (or, bizarrely when I studied it, P=mf!!) does not in any way refer to a turning moment (a la torque) but rather to uniform motion in a straight line.
ABC
ABC
If you really insist, the "correct" equation in angular terms is M = Jε (or T = Iα, depending on where you come from), where M = torque, J is the moment of inertia (rotational mass) of the body, and ε is the angular acceleration.
In this particular case, the only difference between the two equations is a scalar - namely the wheel radius, and I feel entirely justified in skipping this in the name of simplicity, and to illustrate the concept using terms that are familiar to more people.
BTW your "bizarre" equation was probably P = mv, i.e. Momentum = mass x velocity, which is the first integration in time of the F=ma equation. And F=ma is really a differential equation using vectors, so it can refer to any type of force, including one that varies in intensity and/or direction, of which a circular motion is a special limit case. In any case, an accelerated motion is not generally a uniform one (unless you want to consider a particular case in which acceleration is perfectly constant). So who is giving erroneous analogies here?
Aside: What on Earth does "TMI" stand for in this context? Too much information? Where is the "too much"? Perhaps in this post?
My Ride: 2007 550i, Titanium Silver/Black, 6-Sp Steptronic, Sport Package, HD Radio, Sirius, Premium Sound, GPS Nav, Cold Pkg, cell phone cradle, iPod through the AUX port
1976 Datsun 280Z, Charcoal/Black, 5-Sp Manual, A/C, American Mags, CD, Tom Tom 930 GPS (works better than the BMW!) and the rest is pretty much stock
Originally Posted by dlevi67' post='373746' date='Jan 4 2007, 07:22 PM
End result: you accelerate faster by staying in gear and redlining it, than by shifting at the optimal point. And that's ignoring the gear shift time.
Originally Posted by Ricracing' post='373996' date='Jan 5 2007, 02:36 PM
"Stay out of the passing lane, punk!"
Rudy!
I'm with you.
But didn't Znod and his friends do quite a lot of testing and track times for the 1/4 acc?
I'm with you.
http://forums.e60.net/index.php?showtopic=...3&hl=G-Tech ~ post 293 and up
http://forums.e60.net/index.php?showtopic=...6&hl=G-Tech ~ post 31 and up
And we certainly came to much the same conclusion that dlevi67's clear and simple explaination provided. Znod came at it from the more experimentation side with some theory thrown in for good measure. Several of us tried to validate the findings thru experimentation as well.
Just nomenclature.
ABC
Originally Posted by pennetta' post='373735' date='Jan 4 2007, 04:45 PM
I looked at the E60 torque curve for the 545. colejl provided this link http://www.e60.net/information/options/engines/N62B44 for the torque curve. It seems that if you shift at 4200 rpm and drop 800 rpm with an upshift, you will have the most torque available for acceleration and thus quicker acceleration times. Most people and most autoshift programs bring the car up to redline before it shifts. Is torque king for acceleration or is it Horse Power?
The analogy is not an analogy, but it is a completely true statement. The force with which the car will move forward is exactly equal to the torque at the wheel divided by the wheel radius
it's torque. F = ma, as Newton was fond of saying.
ABC
Originally Posted by aybeesea' post='374078' date='Jan 5 2007, 09:46 PM
Torque represented by force. Not properly analagous then.
ABC
ABC
From Merriam-Webster online
Main Entry: anal?o?gy
Pronunciation: &-'na-l&-jE
Function: noun
Inflected Form(s): plural -gies
1 : inference that if two or more things agree with one another in some respects they will probably agree in others
2 a : resemblance in some particulars between things otherwise unlike : SIMILARITY b : comparison based on such resemblance
I think it's pretty clear that torque in a rotational system that transfers the rotational motion into a (roughly) rectilinear one is force... and viceversa. I'm not sure what is more analogical than this. In fact, it's proper duality, not just an "analogy". And I think I pointed out the reason for not using the "correct" rotational equation in my previous post...
BTW - Do you think pistons rotate? Or that combustion and expansion generate "torque" directly?
Originally Posted by aybeesea' post='374075' date='Jan 5 2007, 09:41 PM
My Ride: 2007 530i
Originally Posted by vegastrashed' post='373980' date='Jan 5 2007, 11:04 AM
I have validated this on numerous occasion. Tried shifting at optimal point once and got beat by heezy545i who was shifting at redline. ![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
